come sometime in spring time I plan to get some chrome rims for my car (98 Sunifre GT). But I am corcerned that if I get 17s (which my plan is) I would feel pretty dumb if I hit a big pot hole and damaged the rim since I live in Winnipeg and our streets are @!#$. But if I got 16s I'll be playing it safe and less of a chance of getting damaged............So what would u say is more worth it? Getting 17 and maybe getting damaged with the streets I live in.......or play it safe and gets 16's
unless you plan on running over potholes at 75mph and not slowing down for speed bumps, a 45 series tire (which is what you'll use for 17's) will be plenty of tire.
if your car is not already lowered, please lower your car the right way first or else the rims are gonna look out of place and the car will look all jacked up
if I had a 17 rim with a 205/50 tire would that rub????
theres no need for a tire that big. stick w/a 225/45/17. thats plenty of tire
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]theres no need for a tire that big. stick w/a 225/45/17. thats plenty of tire
ive got these and hit my share of pot holes and stuff and they are fine
A 205/50/17 is actually the same size sidewall as a 225/45/17.
Both will fit fine. I recommend the 225/45/17 for summer use though. The wider tread will give you better traction.
i thought they were similar but wasnt sure thats why i said just go w/ the 225/45
You can use up to 19"s on stock susp. but I know a guy that has 20's on his sunfire but he has air ride . just thought you should know. I can get you 19's and rubber mounted balanced tuner lugs for under $1000.00 Hit me up on any thoghts you might have..
