2 Quick questions!!!!!! - Wheel and Tire Forum
Thursday, November 03, 2005 3:32 PM
I have a chance to but some wheels its 5x100 bolt pattern and the offset is 48mm i believe.
will those fit on my 2005 sunfire?
I guess my 2 questions are
IS my bolt pattern on my car 5x100?
Is 48mm offset ok?
Re: 2 Quick questions!!!!!!
Thursday, November 03, 2005 5:42 PM
well one other question would be what size rim?
yes 5x100 is what you want. that is the lug pattern on j's
yes 48mm is ok. im currently running 18x7.5 w/ a 48mm offset
Friday, November 04, 2005 8:23 AM
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]well one other question would be what size rim?
18x7.5 is what i am possibly buying the exact same thing. no problems with it then???????????
Friday, November 04, 2005 8:36 AM
no problems at all and im running a 225/40/18. if you feel it will rub you can always use a 215/40/18, which is a slightly smaller tire
Friday, November 04, 2005 1:22 PM
so you do not rub or have any problems?
Friday, November 04, 2005 1:25 PM
only when i lay my car out my tire touches the fender but i doubt you'll be laying your car out so you wont have a problem
Saturday, November 05, 2005 7:39 AM
lay the car out??
Saturday, November 05, 2005 7:52 AM
make sure the hub bore is large enough for a j-body. It has to be at least 57.1mm. Most aftermarket wheels are larger than this, hence the need for hubcentric rings. If it's smaller, however, you'll have to have a shop machine it out. This happens on occaision because wrx's and sti's have similar offset and lug pattern, but they use a smaller hub bore (56.1?). I was going to buy a set of SSR GT2's from someone on ebay, but they hub bore was too small.
"The J's weren't designed to be sports cars, the suspension sucks, the brakes are tiny, and the target market for our car doesn't need to be able to do any more than 65mph." - Shifted
A more accurate observation has never been typed. These should be the starting points before any serious performance modification. What's the point of making a serious performer if you can't control it's power?
Saturday, November 05, 2005 10:32 AM
Adam Radford wrote:lay the car out??
its a air ride term. laying the car out means to fully lower the car and lay it on the ground, hence the term laying it out. as for the hub bore. i wouldnt worry about that too much. the majority of the rims you find will be fine. make sure though you do get hub centric rings, you need them. also if you get lugs they have to be 12mm x 1.5mm
Friday, November 18, 2005 8:30 AM
Just thought I'd add that. Most wheels seem to fall around 35-45mm offset when they're 5x100. Subies seem to be the only exception with an offset of 48+mm offset . 18" Rota's subzeros are a good example of the proper offset with a smaller hub bore of 56.1mm. Just a word of caution when buying.
