Hey guys I was just wondering if they make spray paint for rims??? im looking to paint my stock rims black do they make such a thing so it looks nice and glossy?
I would just get them powdercoated i know its a little more expensive but its worth it in the long run trust me
>>>> SPONSERED BY: Cavalier Extreme <<<<
they do actually have a type of "powder coating" paint for wheels...i have seen it in pepboys. i think dupont made it? just be sure to clear coat them...
yeah, i used the paint on mine. it worked pretty good. just do 2-3 coats and clearcoat it. also, tape off your tires, cause it doesn't come off very easy. the clearcoat makes a very nice gloss, just as long as its done evenly. i need to redo mine cause i messed up the clearcoat. its easy if you take your time. it holds up well to. i've had it on since like december with no problems. 2 cans plus 1 clearcoat can should do 4 wheels
ya they make a paint. its called wheel paint. they sall t at canadian tire. liek $9 a can or something. I used 2 cans of color and 2 cans of clear for my rims
<img src="http://www.j-body.org/registry/thadog/MAT.jpg">
"Louis, you better watch who you call a child. Because if I'm a child,
that makes you a pedafile, and I'm not gonna stand here and argue
with a pervert" -- Peter Griffin
Thanks guys ill keep my eye out for it and let you know how it turns out
Stephen Gray wrote:yeah, i used the paint on mine. it worked pretty good. just do 2-3 coats and clearcoat it. also, tape off your tires, cause it doesn't come off very easy. the clearcoat makes a very nice gloss, just as long as its done evenly. i need to redo mine cause i messed up the clearcoat. its easy if you take your time. it holds up well to. i've had it on since like december with no problems. 2 cans plus 1 clearcoat can should do 4 wheels
i painted and clear coated mine, i used minimal masking tape.
it turns out that paint thinner, steel wool and a rag takes off overspray.
old as well as new overspray, just dont scrub the rim.
