im looking for some companys that make light weight wheels. i want 17"s not sure on the style yet im thinking prolly a 5 spoke style. not sure on color either. im thinking silver black gunmetal or polished. any insite on some companys and styles would be great.
i know enkei makes some lightwieght wheels
As far as lightweight 17s for a good price, when I was looking, I wanted a 17x7.5... I found two that I liked that size.
17"x7.5" Kosei K1 Racing 16.7lbs each 35 offset $179 @
www.tirerack.com
17"x7.5" Falken Hanabi ~17lbs each 42 offset $159.99 @
www.1010tires.com
The Hanabi has a better offset for our cars and is cheaper and weighs about the same. I almost went with them but I got a deal on a set of used Kosei K1s.
Look for the motegi track lites, I think they are around 200 a rim.
i like those ro_ja's but i herd they were discontinued is that true? i also like the 5 spoke centerline wheels i dont know the name and cannot find how much they weigh. the motiegi trak light is nice but no 5/100. is there a site that actually tells you the weight of wheels. all the sites i look on have no weight listed for the wheels 1010tires.com lists some but not most.
Wheres the cheap light weight, white 5 spoke wheels?!! All I can find is the motegis which weigh a lot and the gram lites which cost a ton!
Check out Velox ... I've got the PG5 S 17" 12.5lbs. 18" 15lbs.
Velox
i found the name of the centerlines they are called centerline storm but i cannot find the weight of them, i also like the enkei rpm2 they weigh 16.9. those velox pg5 s are crazy light 12.5 ibs they look good too, how much do those cost about?
go with motegi track lites
you can get a set of 4 in 17's in black/gunmetal for 780 or so
where did u see the track lites go for that cheap? the lowest i see them is a grand for all 4
...John, your wheels were EXACTLY the ones I was looking into...how do you like those veloxes? I havent seen em in a while, are they still available? What tires (size, too..heheheh) ya running with em? They look marvelous on your car, btw...
...don't hate!.. respect people that have talent, even if it is in something you don't like or understand.
Another rim I would check out is the Drag DR-8. They're only 15 lbs. for 17's and run about $380-400 for a set of four.
I cant think of the name but they were 5 spoke gunmetal 17's with polish lip that weighed 12.5pounds each ill see if i cna figure it out
208whp 239wtq
13.7 @ 102mph 2.19 60'
^^^^^Those are the Velox PG-5S you are thinking about. Those are the ones that John317 has on his 'fire.
Rota Slipstreams look nice and light.. i was
told the 15" ones weigh 6lbs each without tires but im not 100% sure.
someone had a set of TrakLites and Goodyear Drag Radials and they said one weighs less than a spare tire donut and thats with the tire mounted....cant remember who but it was on AIM, i think it was Josh Roberts with his new cavy aka Minion, so that would be a good setup there.. he only has 2 tire as the drag radials obviously, for racing..
