Got an 02 base model, auto tranny 2.2 ohv, I wanna do a 5 speed swap, I know ive got to relocate the mounts, but I was wondering, what else do I need to do? I'm really new to engine and tranny swaps, in that I know its work, but I think with some help I can handle it.
rear trans mount to frame and bushing
front trans mount to frame and bushing
Cut your auto trans mount off the frame
Shift cables from 00+
Shifter assembly 00+
transmission obviously
New drive shafts for 5 speed
5 speed engine harness and match your stock options abs, cruise, a/c
pcm for a 5 speed
Clutch pedal assembly
Brake and gas pedal assembly for 5 speed
Clutch start safety switch ( splice into the THICKEST YELLOW wire coming from ignition switch on dash harness and before the connection with the engine harness) When you connect it with the engine harness, the wire on the opposing pin will be a thick Purple one.
Fluids
Thats about it.
thanks man, that really helps out alot!
Blue Boosted Penguin wrote:Turbo Tech Racing wrote:You need this bracket also:
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idproduct=5412
He will need the rear one too do your guys make that?
I know both can be ordered throught gm would be good if you could do both!
Both cannot be ordered through GM, only the rear bracket can through GM, that is why we make the front one, only place to get just the front bracket.
-Aaron
www.TurboTechRacing.com
Turbo Tech Racing wrote:Blue Boosted Penguin wrote:Turbo Tech Racing wrote:You need this bracket also:
Makes sense thinking about it now my buddy Connor just did a manual swap in his 04 Eco used your front and gm rear we only had to trim a bit off of it bout half a inch, better having to much then to little lol
worked well tho A++++ made it easy having my car to take measurements off of too. Motor and trany sit perfect looks like it was bought straight from the dealer minus the paint lol
I have a 96 2.4 that im going to be isuzu swapping will the ttr mount work for me and does anyone have the part # for the rear mount?
