Seperating Trans from Block - Transmission Forum
Saturday, February 05, 2011 9:01 AM
Any tips? I've been ripping on it, and can't get it to desperate. Using the haynes manual and says starter doesn't need to be removed, right?
I've honestly layed on the floor and kicked it trying to get it to separate, and i got it to move about a hair.
Re: Seperating Trans from Block
Saturday, February 05, 2011 9:19 AM
I don't know about the started on an Eco, But from much experience, Just look over it again, make sure you arent missing any bolts. And just wiggle and lift with your hoist till it slides out.
Typically, I will drop the entire subframe/tranny/engine and go from there.
Saturday, February 05, 2011 10:56 AM
If you are not getting any separation at all then you still have a bolt in.
Saturday, February 05, 2011 1:32 PM
Take the starter off,and there is a bolt above the starter.you might have missed.
Saturday, February 05, 2011 1:55 PM
I guess I ended up missing one behind the part that holds the shift cables, didn't see it at all. It's out and ready to go now. Thanks!
Saturday, February 05, 2011 10:26 PM
idk about the eco's but LD9s have line up pins in the block that make separation a real bitch while in the car. but... its nothing a long flat blade screw driver or hell, even a tire iron cant solve.
If it takes forever.... I will die trying. Underdog Racing
Saturday, February 05, 2011 11:54 PM
Arp's will ship out Monday. Ill post the install specs for the bolts tomorrow if I remember.
Sunday, February 06, 2011 9:08 AM
Post those when you can please! Loctite on the ARP's? or just oil and torque them?
And PM me your Paypal when you get a chance.
Sunday, February 06, 2011 11:45 AM
There is a tq setting for if you use arp moly. Or a certain weight oil. Ill grab it now.
Sunday, February 06, 2011 12:14 PM
Roofy Online
Lightly coat the threads of the ARP flywheel bolts with 30weight motor oil. Then torque them in a cross.cross pattern to 85 ft/lbs.
Sunday, February 06, 2011 1:08 PM
So no loctite on the ARP's?
Sunday, February 06, 2011 3:41 PM
Roofy Online
No. ARP Moly Lube or 30weight engine oil, Per ARP's instructions.
Sunday, February 06, 2011 7:09 PM
Alright so 30w it is then!
Cool, thanks guys. Just waiting on the bolts
