I was just wondering what normal transmisson temp is on our transmissons
and what temps people are running with a yank 3000 stall?
its a 96 Z24 by the way
thanks
8 psi with m62 and IAT under 100
bump
please anyone lol
You don't want to see much over 200 or 220, ever!
alright thank you ill have to see later this week when my car is running again
Mine doesnt go over 185 under normal driving, it is at about 200 at the end of the track when I race tho.
Do you have a transmission cooler? That seems a but on the high side, still safe though. As a rule of thumb you shouldn't be over 80 degrees above ambient temperature (75 outside + 80 = 155 maxish).
^Yes I have a tranny cooler. I may be a little high on the trans temp at the track(could be a guess) but I know its not above 200. I havent driven the car since last Aug.
Thanks for the rule of thumb, never knew that.
You should be fine, just keep an eye on it.
I posted about this a long time ago....
Click Here....
wow thanks guy this helps alot does that rule of thumb go out the door with a 3000 stall?
It would be a little bit higher than stock. Was is the stock stall, 2500 (sorry, I don't have an auto)?
Mine was about the same with or without my Yank High Stall.
ok thank you
