i was wondering if a getrag 5 speed will directyl swap into my 1997 z24 without any problems
Turbo lag is a courteous head start
No.
Chris
'02 Z-24 Supercharged
Look around alittle and im pretty sure you will find a detailed thread on this swap. I requires some fab work and is not a direct swap.
Curious...will the Ecotec Getrag bellhousing pattern bolt up to a 2.4 LD9?
Bill Hahn Jr.
Hahn RaceCraft
World's Quickest and Fastest Street J-Bodies
Turbocharging GM FWD's since 1988
www.turbosystem.com
No.
Little wider.
Chris
will a G6 6spd bolt up to a 2.4L
JBO since July 30, 2001
No,
But it should to anyother 660....... And I think the 660's and 3800 have the same pattern....
... I like your thinking.
Chris
will a GTO 6speed bolt up to a 2.4?
Bill Hahn Jr. wrote:Curious...will the Ecotec Getrag bellhousing pattern bolt up to a 2.4 LD9?
Nope but if you get the getrag from a 2.4 just swap bellhousing and your good to go! thats what i had to do
the g6 f40 has the same pattern as the 2.2, 2.8, 3.1 ,3100 ,3400 ,3500, 3.4dohc ,3.4ih ,3800..... to swap it u need a flywheel spacer from v8archie. g6 cables, shifter, slave, and custom mounts. and a gto is rwd so def wont fit a cav lol.
Taetsch Z-24 wrote:No,
Chris
hahaha chris totally didn't catch my sarcasim did you hahahahaha
accually thought about the 6spd in my car but they are expensive and hard to find so right now i'm researching building an F23 with possibly using F40 gears, not sure if its even possible but thus is why i'm looking into it gonna compare cost and materials to see what would end up being stronger plus an LSD insert
Schnupper wrote:Bill Hahn Jr. wrote:Curious...will the Ecotec Getrag bellhousing pattern bolt up to a 2.4 LD9?
Yup, case are the exact same on the getrag, just the bell housings need to be flipped...
-Aaron
www.TurboTechRacing.com
scott (section8cav) wrote:will a GTO 6speed bolt up to a 2.4?
Yes, with a T5/T10 Bell housing from QuadRods.com
Dont tempt us Scott.....
Chris
