I have a 2004 cavalier 5 speed, my girlfriend pulled into a parking spot today and the car stalled. Then when she tried to restart it, it starts but you can not put it into gear, there is no clutch pressure, the master cylinder is full of fluid and every time the clutch is pumped we can see the fluid moving through. Any ideas of what it might be??
Hmm Drop the tranny and see what happened. The clutch plate probably got riped off the rivits
]:-> 287 TimeSlips In Hand. Car Still Runs Strong... 3 Differentials Later ]:->
I was able to drive it to the garage, when i start it in a gear i can use the gear that I start it in
Hrmm.... i had the same-ish problem and all i had to do is bleed my clutch good. Works like a charm now.
so took out the tranny, clutch is not bad but would have to replace very soon anyways, as we took out the tranny thought we found a small cut in the hose that goes to the slave cylinder.
Well atleast its all torn out and able to be delt with.
