ok, so i have a 2000 2.2 with the 4t40e, and i want to know if i should keep it as it(with 145000m on it), and wait for it to die, rebuild it now, or try to upgrade to a better tranny. what do you guys think?
this car is going to get much more power hopefully within a year...up to 300hp...maybe a little more, but i doubt it.
and i want to keep it auto.
Hey guys I have a 2002 2.2 OHV engine and tranny. I was tryin to see if the 2.2 OHV tranny will fit on a 97 z24 tranny. Im tryin to put that engine and tranny together. Any help guys. Im also new to this site so im new to this!!!
madjack, i had my car hooked up to a tech 2 at school, and my fdr is 3.91 according to it...are you sure the 2200's only had 3.63?
Demetrius Dallas wrote:Hey guys I have a 2002 2.2 OHV engine and tranny. I was tryin to see if the 2.2 OHV tranny will fit on a 97 z24 tranny. Im tryin to put that engine and tranny together. Any help guys. Im also new to this site so im new to this!!!
im going to go ahead and say a 2.4 tranny will not fit a 2.2 ohv and i believe the 2000-03 use getrag
correct me if im wrong
i thought that was the 03-05's that used the 5 speed manual getrag transmission.
MadJack wrote:If you going to be pulling the engine at a later time, plan on doing the transmission at the same time. If you've been reading this thread, I gave a quick explanation as to what can be done, with the help of Chris (Taetsch Z-24). Keep the money to have it rebuilt ready, just incase problems arise. In the mean time assemble the parts you want to go in it before hand, unless you've got a reputable shop that carries all the parts. Also, with the 2200 you have a 3.63 final drive ratio, you can move up to the 2.4L TC/Z24's 3.91 final drive, if you move the powerband up any.
Between what MadJack said and my build thread
TurboCavalier98's Trans build You should have more than enough info to make a solid determination on what you want to do with your transmission. Good luck.
Josh Ferry wrote:Demetrius Dallas wrote:Hey guys I have a 2002 2.2 OHV engine and tranny. I was tryin to see if the 2.2 OHV tranny will fit on a 97 z24 tranny. Im tryin to put that engine and tranny together. Any help guys. Im also new to this site so im new to this!!!
A automatic 2.4L tranny is a 4T40E same transmission I have in my 98' 2200 boosted Cavi.
Josh G. wrote:MadJack wrote:If you going to be pulling the engine at a later time, plan on doing the transmission at the same time. If you've been reading this thread, I gave a quick explanation as to what can be done, with the help of Chris (Taetsch Z-24). Keep the money to have it rebuilt ready, just incase problems arise. In the mean time assemble the parts you want to go in it before hand, unless you've got a reputable shop that carries all the parts. Also, with the 2200 you have a 3.63 final drive ratio, you can move up to the 2.4L TC/Z24's 3.91 final drive, if you move the powerband up any.
Between what MadJack said and my build thread TurboCavalier98's Trans build You should have more than enough info to make a solid determination on what you want to do with your transmission. Good luck.
I thought the 4T40E tranny was exclusive to the ecotec engines, didn't know they used the 4T40E trannies in the LD9 engines too.
