Its neat and all, but all you need to "build" an auto is
A good pump (4T40's are known for eating pumps)
Quality clutch packs
A good high stall converter
and program your own shift points and line pressure.
I would say that trans is "a little" over priced.
Chris
'02 Z-24 Supercharged
considering a stocker can take quite a bit of abuse and and seeing as how millions of them are out there ripe for the picking for cheap... why blow 4k on one of these?
unless of course it actually takes LESS power to turn the biotch... ??
Are you scared of the changes coming? The answer is on the inside.
Most j-bodies aren't even worth 4k, haha.
Put a real trans in your car if you're that serious.
^^^ huh? more info on the 'some stocks rated at 2975' please.
My old 84 "T" truck Blazer was rated at 2200....
I miss that thing.....
Wonder if the older THM125's from the early\late 80's have a higher stall?
Chris
so, what does something like this tranny do over stock?(better shifts, longer life, and can take more power?)
well im gonna be rebuilding my 4t40e sooner than later and i already for most of the parts i need for it
yall forgot to ADD a LSD to the auto list of nice upgrades
MadJack wrote:Chris has it right:
Taetsch Z-24 wrote:Its neat and all, but all you need to "build" an auto is
Quality clutch packs (Raybestos Blue Plate Special Stage-1 Complete Module # RCPS-29)
A good high stall converter(Yank 3000 stall TC, if you can find one, or custom. Some stocks are rated to 2795 rpm stall)
and program your own shift points and line pressure. (H.P. Tuners-Best, B&M ShiftPlus-alt.)
Chris
I have to agree 100% with MadJack.
Also maybe a Team Green LSD, and you would be set.
Does anybody know if # RCPS-29 will fit 4t45 applications? If so you guys have helped me immensely.
After what my trans did today after a first gear burn out. I think its time for a trans swap, auto's HATING the boost lol
whats the price range on building up the 4t40?
8 psi with m62 and IAT under 100
