I have a 96 Z with the Isuzu 5spd. I lost my bag of bolts for my transmission and wondered if anyone had the list of sizes or worked for gm that could get a copy of the service manual page that has them so i can go to ace and pick up new ones. thanks guys
"sometimes the respect is more important..."
No junkyards in your area? Just wonderin
yea there are 3 good ones and i checked all of them with no luck
just go to down to the dealership and ask for all the tranny-to-engine bolts.
your probly going to have to buy them in bulk though (usually 10 to a bag IIRC)
actualy your in quite luck lol. i currently have my mr1 laying on the ground in the garage lol (broke another clutch). If i do remember correct the are m12x1.5 but i can check the actual sizes and such. i should be heading back out maybe tonight or mid day tomorrow, but i will get back to you
Well i made a special trip out just for you lol ( plus i was kinda bored)
This Pic is the proper location of the bolts, do remember that there are 2 bolts going into the transaxle from the passenger side...( one is through support brace, the other through the block)
Here are the 2 different bolts used to secure the bellhousing to the engine:
Left side (M12x1.75x44mm with an 18mm hex) Right Side (M10x1.5x19mm)
M12x1.75x45mm with an 18mm hex
Here is a list of most of the bolts involved mounting in the MR3/MJ1 Izuzu 76mm transaxles
QTY - Bolt size..............hex....................notes
Bellhousing to engine bolts:
4 - M12x1.75x44mm 18mm hex with M10x1.5x19mm stud
2 - M12x1.75x45mm 18mm hex
4 - M10x1.5 Nut 15mm hex
Transmission support bars:
Front:
3 - M10x1.5x30mm 13mm hex Measured Below washer
Rear:
1 - M10x1.5x30mm 13mm hex
1 - M10x1.5x44mm 13mm hex Bolts into transaxle
Transmission Mounts:
Front:
3 - M10x1.5x33mm 13mm hex
1 - M10x1.5x100mm 13mm hex
1 - M10x1.5 Nut 13mm hex
1 - M10 Washer
Rear:
1 - M10 Washer
Starter Bolts:
1 - M10x1.5x113mm 15mm hex
1 - M10x1.5x45mm 13mm hex
1 - M10x1.5x20mm 13mm hex Support bracket to block bolt
Shifter Cable Bracket Bolts:
3 - M8x1.25x18mm 13mm hex
Inspection Cover Bolts:
3 - M8x1.25x22mm 10mm hex
I appologive is anything is incorrect or has variations. I based this off a car that is currently apart and assumed that the fasteners are original. Also i have pictures of all the bolts and related hardware that i listed here, so I can supply high resolution photo if required. You should be able to use m12 bolts assuming the the eyelets on the ground terminals are big enough. Hope this if of some help to people.
Corey your awesome I really appreciate the info!!!! Thanks for the effort and time!!!!
I will take a look around in the bolt bins when i get a chance today and see if i can find one or 2 of them stud bolts. No problem i'm just happy i could be of help
