The flywheel has four main purposes.
1. crank the engine through the help of a starter motor.
2. connects engine's crank to the trans.
3. stores kinetic energy untill the next power stroke.
4. absorb vibrations from the engine.
The flywheel, an important part of the engine, is also the main driving member of the clutch.it is normally made of nodular or grey cast iron. Welded to or pressed onto the outside diameter of the flywheel is the starter ring gear (what the starter splines to). The large diameter of the flywheel allows for an exellent gear ratio of the starter drive to ring gear, which provides for ample engine rotation during start up.The rear surface of the flywheel is a friction surface machined very flat to ensure smooth clutch engagement. The flywheel also provides some absoption of torsional vibration of the crankshaft. It further provides the enertia to rotate the crankshaft through the four strokes.
The flywheel has two sets of bolt holes drilled into it. The inner set is used to fasten the flywheel to the crankshaft, and the outer set provides a mounting plate for the pressure plate assembly. A bore in the center of the flywheel and crankshaft holds the pilot bushing or bearing, which supports the front end of the transmissions input shaft and maintains alignment with the engine's crankshaft. Sometimes a ball bearing or roller needle bearing is used instead of a pilot bushing.
Dual-mass flywheels are often used to reduce vibrations transmitted through the transmission, which gives smoother shifting, and reduces gear noise. The flywheel consists of two rotating plates connected by a spring and damper system. The forward portion of the flywheel is bolted to the end of the crankshaft and smooths out the crankshafts oscillations. The pressure plate of the clutch is bolted to the rearward portion of the flywheel. Engine torque moves from the front plate through the spring and damper assembly to the rear plate before it enters the transmission. Some have a torque-limiting feature that prevents damage to the transmission during peak torque loads. The rotation of the two flywheel plates can differ by as much as 360 degrees. This allows the front plate to absorb torque spikes and not pass them along to the transmission.
please make sticky.
Displacement= 2.2L
Valve Train= OHV
Bore & Stroke= 3.50 x 3.46
Compression Ratio= 9 to 1
Net HP @ RPM= 125 @ 5200
Maximum Torque Ft Lbs @ RPM= 135 @ 4000
Fuel System= MFI
Normal Oil Pressure: psi @ 3000 RPM= 56
please make sticky.
In your dream. This post is useless.
Gilles
2.3 Ho
Rich Grayo Jr. wrote:our cars do not have pilot bushings.
read the whole thing before you post
Displacement= 2.2L
Valve Train= OHV
Fuel System= MFI
it was off to a good start but then just.. ya nothing
I'm disappointed
i did read the whole thing. i was merely stating the fact that our cars are some of those which do not have pilot bushings.
That guy need attention. He want everybody to look at him and think he's god. First came here, got owned for being dumb. Then did a post about how the site s***, then a post about how our cars s*** then try to do stickys? Get a life.
Gilles
2.3 Ho
I saw the title, and the author, and thought this thread was going to tell us about some new invention; flying wheels. ha ha
what site did you copy that from?
edit:
found it
http://carkipedia.blogspot.com/2007_02_01_archive.html
look under Clutch Operation
Edited 1 time(s). Last edited Monday, February 26, 2007 1:33 PM
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
Mfk-223 wrote:That guy need attention. He want everybody to look at him and think he's god. First came here, got owned for being dumb. Then did a post about how the site s***, then a post about how our cars s*** then try to do stickys? Get a life.
thats a fact, i just got owned again hahahahaha and by the way i didnt get that from a web site or a post i went to an automotive school in nashville an had to do a report on flywheels in transmission class, it came straight from my brain not some one elses so give me a cookie. lol
Displacement= 2.2L
Valve Train= OHV
Fuel System= MFI
Jbody305 wrote:Mfk-223 wrote:That guy need attention. He want everybody to look at him and think he's god. First came here, got owned for being dumb. Then did a post about how the site s***, then a post about how our cars s*** then try to do stickys? Get a life.
no its didnt...what you typed is word for word whats ont he site.
GTFO
holy s%*! thats freakin wierd i swear i didnt get that info from that site, i typed it last night off the paper that i hand wrote in school and did not copy off of any one
Displacement= 2.2L
Valve Train= OHV
Fuel System= MFI
Jbody305 wrote:holy s%*! thats freakin wierd i swear i didnt get that info from that site, i typed it last night off the paper that i hand wrote in school and did not copy off of any one
Clearly your paper is plagiarized then.
"The Blue Bullet"
Redzed99 wrote:I saw the title, and the author, and thought this thread was going to tell us about some new invention; flying wheels. ha ha
not so much
Displacement= 2.2L
Valve Train= OHV
Fuel System= MFI
cause this thread is awsome hahahahahah
Don't forget about this post where he contradicted himself and was proven wrong.
Boo-yah
