I just recently put 18's on my car and now when ever i go over 100km/60mph it starts to shake. Tires have been balanced, do I need an alignment
Did they balance them on the inside or outside?
Have heard that it is more accurate on the outside.
How many miles does the car have?
Yea, ummmm. I used to have a J-body...
make sure the lugnuts are tight
i heard somewhere that you need to remove the little metal things by the disc brakes that are there stock.... just a thought... might be wrong
Do you have hubcentric rings?
they balanced them on the inside
well for one . make sure you dont have any Brake clips on ur studs . if you do then that is what would cause the vib for you . if not I would have them Balance the wheels with tape weights on the inside of the wheel both front and back of the inner wheel . or could just easly be you need centric rings or tighten lugs
