I had my '99 Cavalier Z24 flywheel resurfaced for the new clutch I'm putting in. I didn't pay attention when I took the flywheel off and am wondering if there is a certain orientation it must be bolted on? The flywheel has 2 large holes drilled opposite of each other, and the part on the motor it bolts to has so smaller holes drilled out opposite each other. I am wondering if the flywheel has to bolted a certain way in relation to the holes drilled out(I assuming for balance).
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
The flywheel is zero balanced, so it makes no difference where the holes are pointed.
sig not found
