front and rear tranny mounts, are they worth the 50 bucks?
Well if you have the motor mounts than yes I would definetly say get the transmission ones. Thats like haveing one side of the motor stiff but still loosing on the other loose side. I just installed the ones on my car and its definetly noticable.
Hey Josh if you decide to purchase them we have them on a special for only 39.99. It stock and ready to ship out.
-Aaron
www.TurboTechRacing.com
Definitely worth it... in my humble opinion....
Tim Pietraallo wrote:Well if you have the motor mounts than yes I would definetly say get the transmission ones. Thats like haveing one side of the motor stiff but still loosing on the other loose side. I just installed the ones on my car and its definetly noticable.
I would agree...If you stabalize one side make sure you do the other side. It only makes sence.
-Aaron
any good install faq's anywhere, does the tranny have to be removed to change both?
No the trans does not have to be removed. Just do 1 mount at a time and unbolt it from the trans. Then insert the new bushing and re install the metal mount. It is fairly simple IMO.
-Aaron
Sounds easier than it looked, one mount looked like i could get to it, the other looked worse (this was from under the vehicle in a bay at work).
Doh, forgot, 2.4L Isuzu tranny...
The mounts are in the same location and they are the same for the 95-05 manuals
-Aaron
my Haynes Manual doesnt show them, how ever i did find the front mount, and boy is it cracked up looking (probably from the RKSport motor mounts) the rear i believe i saw once, its in the back if i remember, any tips on getting that one out?
Get it from under the car, make sure you support the trans up.
-Aaron
