Id like to see some dyno sheets of 8psi on eco's and what type of turbo you have and what rpm full boost is reached on your setup. Also what manifold you have. Just curious what you guys are running? Im running 7.8psi with 206hp 229ft/lb torque on my third dyno pull. .42 .48 t3 xs power turbo. Yes i know the turbo is bad please i dont need eleventy billion posts on flaming my turbo haha
it will soon be swapped just curious in what you guys are making and maybe how much your costs to turbo setup are?
*2012 mazdaspeed3*
at 8.7 psi I put down 205 whp and 240 wtq with mid 12 a/f's on a t3/t4 with .48 ar exhaust housing and 50 trim compressor
full spool by 3100 rpms
LE61T PTE6262 Powered
forgot to say that was with my exhaust at 2.25 inch and stock ignition with ecu problems...
yeah im pretty sure i could have leaned it out a bit and made more hp i just got water injection kit and hope to put down some more power. That dyno run was also with stock clutch slipping
hah soi have the spec stage 2 and the wi and im gonna do a tb and go back to ams and see what i put down.
*2012 mazdaspeed3*
6PSI...218HP/224Tq
12PSI...260HP/278q
full boost near 3K
12:1-12.5:1 AF throughout
HRC Super 16G turbo
5K PB: 24:50
10K PB: 54:26
haha oh hypsy why bother i know what you run
we talk on aim all the time but no seriously thanks for the post. Id actually like to see that dyno run
Keep em coming guys i want to see those guys who are saying 50 trims are too small and what not i want to see there size turbos and what kind of performance gain they see from running bigger turbos. Oh and by the way i get full boost at 2300rpm.
*2012 mazdaspeed3*
even though i am a 2.4 Auto I will post for you to compare. a./f ratio was pig rich at a 10.0 afr.....
7psi for me was 190hp and 195tq on a t3 super 60 .
01 Z24 Turbo /// First Reflashed Turbo AUTO MMMM YUMMY
thanks drag race so your around the same power if you lean it out alot.
*2012 mazdaspeed3*
you need to update your registry and car domain site . I would like to see some pics of your setup. I am in Illinois also south suburbs.
the next big trend...... not even getting fully spooled until redline
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
