Turbo
I searched for info on ball bearing turbos but didnt find much......was wondering if this would be a good selection for an eco and just other general info on the BB turbo...Thanks in advance
i wouldnt go smaller than a gt30.
but then again, you can score a bb t28 off or a jdm nissan for around 400.
that sounds like a descent choice.
Well i dont intend on goin more than 300 whp so i figured this would be a good choice and maybe less lag
matt,
thats what im gonna try soon on my 2.4. it looks like a good selection and for what i got it for $250 slighty used from my friend. what a buy.
"IF YOU PERSIST IN DOING WHAT YOU HAVE ALWAYS DONE .....
EXPECT RESULTS NO DIFFERENT FROM WHAT YOU HAVE ALREADY ACHIEVED"
Call Majestic Turbo in Waco,TX; they will answer all your needs and have GT turbos in stock.
All of Texas BIG DOG cars go to them, they are well respected.
majestic turbo... listening, do they ship? do you have their number? thanks
majesticturbo.com
They ship, modify turbos, rebuild high performance turbos, offer great tech and service, basically everything.
They are anybodys one stop shop for turbos whether your just trying to dyno 200 hp or 1500 hp.
Personally, when I get boost, I want the GT28RS aka the Disco Potato
Some times the best way to get that tailgater off your but is to light a fart.
I'm using a turbo from a 1990 R32 Skyline type-m. In the later model years the turbos were roughly super 60 compressors but with twin ceramic ball bearing and a ceramic turbine shaft/wheel, supporting about 320 hp at 12psi. Mine has an HKS composite compressor wheel as well. Awesome stuff.. Look for a Nissan 16v or a 45v1, 45v2 or 45v4.
The 45v1 was on single turbo VG30 Fairladies and is the biggest BB Nissan turbo of them all.. it even came with a composite compressor wheel stock. The other two came on RB25DET R33 skylines and have slightly bigger turbines than the type-m R32, but a smaller compressor trim.Hybrids are doable, just have it balanced. Beware though as ceramic turbine wheels don't like to spool over 15psi.. and watch your EGTs.
Cardomain|
Myspace
GT28R will only be good to about 280 wheel and thats with very good tuning (and by very good tuning, i mean a retuned ecu)... that's what most 1.8T's with good software max out at on that turbo. Not saying this as anything against the turbo, just letting you know. They are however cheap, and will spool like a mother on a 2.2
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
^^^800 $ US at blaastperformance.com. you call that cheap ?
15.574 @ 89 mph stock
correct me if I'm wrong please, but AFAIK Garrett BB turbos still cannot be rebuilt...
fortune cookie say:
$720 at kinetic motorsport, and for a brand new ball bearing turbo, yes, it IS cheap. But then again i'm not the typical cheapass J-owner either.
Eco
Turbo
Megasquirt
'Nuff said
hey... if we weren't cheap, we wouldn't buy Js lol
