people are putting injectors on the intercooler piping before the throtle body? does this work? and how do you wire it up? i have stock injectors on my 99 turbo Z24 and i am at 8psi. someone said if i put stock 97 injectors on my intercooler piping before the throttle body it would make a huge difference. does anyone know anything anout this? if you do please give me the info so i can do it!! thanks
where can i get this setup?
or an Haltech F5 like mine.
Gilles
2.3 Ho
I was running a Greddy Rebic III on my last setup to control two secondary 450's on 10psi on a 48/60. If your running 8psi on stock injectors, I would take it your turbo is not very big or your just really ballsy. Two secondary stock 240cc injectors would not be enough for 8psi on most setups, but again I can not speak for yours as I don't know what you're running. Also, my rebic is for sale if you are interested. email 98redcavz24@gmail.com
Blew it up
i have a t3 .48 ar on 8 psi it hit hit 10 psi today. i am afriad its going blow AGAIN. how much you want for that setup and will it work with out having to buy more @!#$? is everything i need with the kit?
Yes but you are going to need to buy two injector bungs. If you want I could cut that senction out of my intercooler pimping with the injectors and bungs still in it. Then you could coupler/weld it in wherever you want. The injectors i'm using are 450cc's (two of them). I'll give the eholw thing to you for 250 shipped. Let me know via email. This isn't the place to be discussing sales.
Blew it up
