sup guys...
My friend has a turbo off of an sr20det engine...
the specs are as follows:
"Turbo specs:
Compressor: T-25, 60 trim 56mm BCI-1 compressor.
Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing.
Center Section: Journal bearings
Performance:
The stock turbo will be safe to 13-15 psi. After that, the turbo is past its efficiency range, and power increases will fall off and are not worth the risk of turbo damage. The engine should produce 230-250 RWHP at safe boost (used with the sr20det engine."
Here's the deal... I can get it for dirt cheap... My goal is a cheap and reliable turbo kit which produces at least 200 whp.
1. Is this a good turbo for this goal ?
2. How about upgradability ? How easy would it be to change just the turbo afterwards after I'm bored with 200 whp ? Will I have to change the manifold and flange or are there bigger turbos that will fit on there ?
So what would you guys do if you were me ?
15.574 @ 89 mph stock
the t25 is going to a little on the small side for your motor. its gonna get really hot. as far as the flange i dont think there is many biggger turbos that have the same flange.
QBE (73H 800573D 0N3) wrote:to small...
I agree.....
but ........
I believe Hahn uses t25 small and big 16g turbos........ TDO5 ????
Those aren't too small ...............
Lee
JDM Civic Hatch
its pretty small, but, since you guys are reving to the moon, i think you will stay within its map descently, it would do ok if you ould get it really cheap.
also, i do believe the t25 off the redtop has a larger exhaust housing. but maybe thats the t28.
s
it's a T25 my buddy put one on his lancer rs (cnfx turbo lancer) it amde good power but I think it is way to small for our cara
LE61T PTE6262 Powered
I wonder about that, since it's making 250 whp on a sr20det... they are 2.0 liters and the eco is 2.2... is there such a big difference between the two ? What specifically in the sr20det makes it good for them and bad for the eco ?
Personally "I" think it is too small. I would not use it. you can but youre goign to have to run a lot fo boost to make the same numbers that someone else may be making on a t3 super 60 or t3/t4 and its going to run REAL hot.
It's not because it "can" produce a certain amount of Hp on 1 engine that it will no the other. You need to learn more about turbos. It's more than size and psi.
250whp on a T25 is way past it's efficiency and it won't be reliable. Get a T3 super 60 like the rest and enjoy your choice cxause that t25 will not be good.
Gilles
2.3 Ho
I know that engines affect how turbos will perform... I was just asking what was the main differences between the sr20det and the eco that made that difference in power-making.
And BTW I did say in my original post that I would be happy with 200 whp for a while.
it's an sr20 nuff' said...
sorry but an sr20 is an amazing engine... that head must flow a bitch!
yeah I guess lol. oh well. I guess I'll wait and get a real turbo. Sucks cuz i could get it for about 200 $ CAD which is about 170 $ for you US people.
brandon is running a small turbo from the high boost saab
and its a wicked ride , cause boost hits at a very low rpm
if your only gonna street drive the car , and maybe race it once or twice , then smaller turbo will work out more in your favor , cause they come on hard at low rpm , where you street drive the most
how does the t25 compare to the saab one ?
i think the low boost uses a t25 or a t28
and the high boost is a mitsu
the only problem i see is building a kit for a turbo of another car is if your unhappy with it , or decied to use a larger turbo , then you gotta redo alot of work
Lee wrote:QBE (73H 800573D 0N3) wrote:to small...
I agree.....
but ........
Lee
Hahn uses ONLY Mitsu turbos. The Super 16G is a TD05-16G-10CM2. The standard 16G turbo that they use for Eclipse upgrades is a TDO5H-16G-7CM2. They also use a 15G on their 2200 turbo kit which is a TDO4HL-15G-7CM2. They also have a smaller 13G unit that they use for 9B turbo replacements and bigger units like the Super 20G, a nice hybrid unit (TDO6H-20G-TDO5H-10CM2) and Super 25G.
I have the Super 16G and can vouch for how low in the RPMs this thing kicks. In 4th gear from a 1500RPM roll I can have full boost (10PSI at time of testing) by 3000-3100RPM and 15PSI by 3300RPM.
5K PB: 24:50
10K PB: 54:26
DanteMustDie wrote:sup guys...
"Turbo specs:
Performance:
1. That T25 should be just fine for a 200whp 2.2 not reving passed 6500rpm.
2. An upgrade can be as simple as a direct turbo replacement with something like a Garrett GT28R or a GT28RS which can support over 300whp.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
^^^^ yikes talk about an upgrade the gt28r is 800 $ US !!!
If I upgrade to something else can I just change the turbo and flange or do I have to change the manifold too ?
If you want to upgrade to a turbo that does not use a T25 turbine you can just have the flange on the manifold cut off and have which over flange you need weld onto it.
