I was just wondering the pros/cons of wrapping the turbo and header.
"I know not with what weapons World War III
will be fought, but World War IV will be fought
with sticks and stones."
-Albert Einstine-
I've heard many horror stories of the wrap holding in moisture and rusting the parts to pieces. I wouldn't do it, personally, but I have heard that there is a special sealant for the wrap to block moisture. Even so, I wouldn't risk it.
Blown.
Wrap = bad on a daily driver. Imagine what happens after you wrap something that normally dissipates heat as it expands and reacts with the ambient atmosphere.
Something's going to break down!
Saab Turbo Project... 2006
never us wrap. it will wrap your car =BAD
my downpipe was wrapped but then again my car is never driven in the rain...
I don't get it.....
Does Stainless Steel Rust .....
I thought it didn't.............
So could I use wrap with my s.s d.p ??
since it shouldn't rust ........ at all ............
Lee
JDM Civic Hatch
it depends on the grade of stainless
the higher the grade the longer it will take , if it ever does
do a search for the post i had in performance about header wraps , youll love the carnage pics
[quote=97cavie24ls(JDM&00s/c sedans™)]it depends on the grade of stainless
If I remember correctly they used 304 Stainless mandrel U bends to create my downpipe....
could I wrap it and not worry ............... or should I send it out with my manifold to get ceramic coated ................... only 150 for both if I do it ........ wrap from work is FREE......
Lee
JDM Civic Hatch
Cool! Thanks guys....
Got it...Wrap is the devil...on a daily driver anyways...
-Albert Einstine-
Lee - if I were you, I'd get it ceramic coated. The solid protection is worth the extra money. Wrap is questionable, which is why I wouldn't use it.
Blown.
id get it coated also
race only or a weekend car , that doesnt get driven excessively , wrap would be ok
