how do you install an LT1 fpr on a 2200. Any help would be appreciated.
same as the stock 1
just make sure you know what fuel pressure your at with the stock 1, so you can copy it to start with the LT1
yup. same way. there is that retaining screw that holds it into the fuel rail. unscrew that, and it should pop right out. you'll leak a little bit of fuel, just keep a rag handy
im guessing this will not work on a 2200?
CLICKE ME!
it should work with the 2200 fuel rail.
Phlatcav wrote:im guessing this will not work on a 2200?
CLICKE ME!
I notice they offer 2 types, what one would work?
i foget which 1 the 2.4 uses , the mounting tabs are what you need to go by
the corvette and camaro have the mounting tab on oppisite sides
sweet! that answered that
You want the one for the corvette if you have a 2.4. I honestly dont know about the 2.2. Someone else might be able to chime in here.
Brandon
2nd Place is the first loser
so no clue what one for the 2200?
Brandon Hetrick wrote:You want the one for the corvette if you have a 2.4. I honestly dont know about the 2.2. Someone else might be able to chime in here.
Brandon
i heard you need the one for the camaro if you have a 2.4.......can anyone else verify this
no love for the eco guys?!
2.2 L Ecotec, P&P Head, Stage 3 Comp Cams, Supertech 76 lb Spring kit, Supertech Oversized Valves, Wiseco 8.9:1 CR Pistons, Eagle H-Beam Rods, Home-Built Turbo Kit T3/T4 57 Trim Intercooled, 78 lb/hr Racetronix Hi-Z injectors, Aeromotive FPR, Racetronix f body fuel pump,MEGASQUIRT MS3 + MS3X Finally street tuned on 21 lbs! Now if only I could get it to hook....
yeah i heard the lt1 fpr works on the eco, is that true?
cavipower1 wrote:yeah i heard the lt1 fpr works on the eco, is that true?
http://www.j-body.org/forums/read.php?f=2&i=278137&t=278137
Tobbe F wrote:
"2003 ecotec owners can now have a afpr that will directly bolt up to the fuel rail. it is a
1995-1995 Lt-1 fuel pressure regulater that i picked up from holley but jegs has a aeromotive part # 027-13107 . it has to have the bolt on the font and have the fuel line fitting on the right . you will also need a fuel pressure gauge that can be tape on to the shrader valve. if you have a 2002 cavalier you will need a fuel rail and lines and injecters from a 2003 cavalier.
NOT to thread jack.... but
For those asking about the 2.4 AFPR, here is the one I just got from summit. Its an LT1 and hooks directly up to the fuel rail. Only thing is, the nipple faces the opposite way from stock. SORRY FOR THE CRAPPY PIC!!
2012 numbers - 4SPD
AUTOMATIC!!
Aeromotive AFPR
13106 '92-'96 LT1 Corvettes (2.4)
13107 '94-'97 GM LT1 F-Body (2200)
Does that pic help?
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
13106 fits the 2.4
13107 will fit the eco 03-05
you guys with the 2.2 you need to see what side of the fpr the mounting tab is
that will tell you which 1 you need
