i have a 99 z24. i am at 11psi on stock injectors. i want to upgrade, but i want the new ones to plug in, is this possible? what and where can i get the injectors i need?
I reccomend fuel injectors for use in boosted applications.
stock injectors and 11psi .........a lil scary
boost makes my girlfriend wet....
the ones from the gm supercharger kit fit. the ford brown, red, and green tops are good choices but they require some fabricating but i hear its not that bad. i also think rsm makes some. im sure there are more. the ford ones will be cheaper.
"IF YOU PERSIST IN DOING WHAT YOU HAVE ALWAYS DONE .....
EXPECT RESULTS NO DIFFERENT FROM WHAT YOU HAVE ALREADY ACHIEVED"
UncleD wrote:stock injectors and 11psi .........a lil scary
Dude this is this guys second motor..... he blew the first one because he was at 11psi on stock internals and injectors..... OUCH..... DUDE GET FORD BROWN TOPS.... THEY WILL WORK GREAT... just get an AFPR as well to control pressure at idle...
Lee
JDM Civic Hatch
how are you managing fuel? fmu or something electronic like an e-manage? you really need to pick injectors based on the power level you plan to reach. also your year should use peak & hold injectors (mine did) if the stock ecu is still in place you will need to make sure to replace them with the same type. RC makes affordable ones that will do the job just fine and are available in a variety of sizes. hit us up with some more info about your setup and im sure you will get several good solutions
as for pluging in chances are you dont have the standard bosch style injector plugs. i am not aware of aftermarket injectors that will plug into those but if your anywhere near va i have a harness that does and your welcome to it.
I would pick up something like the RC Injectors (370cc). If you need some, let me know. Our price is $369.99 shipped:
sales@maximumboost.net
MaximumBoost.net
1-888-TURBO-31
TAX ID: 45-8013458577-3
Roscoe wrote:how are you managing fuel? fmu or something electronic like an e-manage? you really need to pick injectors based on the power level you plan to reach. also your year should use peak & hold injectors (mine did) if the stock ecu is still in place you will need to make sure to replace them with the same type. RC makes affordable ones that will do the job just fine and are available in a variety of sizes. hit us up with some more info about your setup and im sure you will get several good solutions
my setup is:
ld9 stock internals
stock tranny
t3 50trim turbo, 11psi
2.5 intercooler piping
hks bov
short thorw
stock injectros( i think)
stock fuel pump
open down pipe
I'd invest in some larger injectors... 370cc injectors sound about right.
stock pump also? man ur lookin at a third motor goin this rout. get at least injectors and a pump. mine started to go out at only 8 psi
You have a 3rd motor in your future if you don't smarten up and upgrade the weakst points of your car.
-Injectors
-Fuel pump
-Tranny
-Rods/Bearings
-Oiling system
Also, you don't seem to have any kind of Fuel Management in your list.... are you kidding?
Why do people spend $300 - $400 on a stupid fancy-sounding blow-off valve but can't spend $400 on injectors, a pump and an FMU and fuel pressure gauge?
Jeeze....
-Chris-
-Sweetness-
-Turbocharged-
SunfighterGT wrote:Why do people spend $300 - $400 on a stupid fancy-sounding blow-off valve but can't spend $400 on injectors, a pump and an FMU and fuel pressure gauge?
that's so true. and you sir are on a roll today.
