Well.....for those of you wanting to get the 5 rib pulleys....they are fixed now so you dont have to worry about them grinding on the supercharger
Now I put the pulley on the other night.....so after a day of playing around with the fuel crap I got my a/f's into the low to mid 12s.........
So for those of you wanting to get the 2.6 I would recommend doing so...Cause there is a very noticeable difference between the 2.7 and 2.6............
I haven't given the boost gauge a good look yet.....but my buddy said he glanced over and saw it at 9psi or so.....so I'll have to see for myself..
Any questions/comments are welcome Thanks!
MUST HOLD BACK FROM PURCHASING ASAP!
Running all GM S/C fuel/reflash stuff still? Or do you have upgrades?
I plan on going with the 2.6 and alky injection, but need to know if I need to consider anything else!
same here
but i might have something else up my sleeve lol......prolly not just something to think about
2000 Camaro V6.
Joe- I am running no reflash since I am a 99....but I'm usin the injectors from the kit, cartech fmu, walbro fuel pump, and the alky kit. I've also got secret cams...
And YES you need to buy it ASAP!
Yea I know what you got up your sleeve hehehe.....
I need to get to the track....
I guess I should just go with it, then get her to the dyno for a couple tuning sessions to make sure I'll be safe.
It'll be here by Spring, no rush!
Joe Schulte (JoeDM) wrote:MUST HOLD BACK FROM PURCHASING ASAP!
I am running every thing stock like fuel pump and such with a 2.6" pulley and no problems at all but i do have alcohol injection
The First Twin Charged jbody
^ thats interesting...... i wonder how your pump is holding up?
I'll also be ordering a smaller pulley, math says 2.6 is the smallest I can go before going over 16k rpm at redline.
I'm curious what kind of psi gain that would give me
Although I'll probably just go with a 2.8 for the time being.
^^ What size pulley come stock on ur s/c???
Bobby(Blown&Pullied) wrote:^^ What size pulley come stock on ur s/c???
3.34 is the stock size, which right now hits 10psi on my setup.
Guys with the cobalts hit 12-13 psi with the stock pulley and 18 with the 2.8
john is your crank pulley a different size than the 2.0 eco motor ?? the cobalt guys are talking like 2.8 is the smallest before 16k
i gotta figure out my pulley size , so i can go larger
also i was lean with the kit injectors , i got 36lb 1's from the 2.0 sc now , must better afr with them
[quote=97cavie24ls(JDM&00s/c sedans™)]
How much were those? Plug and play on the 2.4l?
i wish they were , they plug in no problems (electricly)
they are shorter than our stock injectors , and i had some spacers made , that made them to long , and the spacer was made as short as possible
ive got the venom fuel rail so it has bolt on legs for the mounting to the head so i spaced it with some washers , and right not ive got a vacuun leak because they are being pushed to far in the head
so if got to get some longer alen/bolts so i can use another washer , ive got someone helping out with this project , and we are trying to come up with a way to make them work out with minimal work , ive all works out , there will be some copies made and sold
but on boost my car runs a whole lot better now that i can see a/f ratio's in the mid to low 12 range
Viper98912 wrote:^ thats interesting...... i wonder how your pump is holding up?
so far no signs of it hold me back... a guy i just bought the turbo kit from used his stock pump and was runngin 10psi of boost and had no problems and his wide band i gues read perfect air/fuel mixer even at 10psi....
[quote=97cavie24ls(JDM&00s/c sedans™)]i wish they were , they plug in no problems (electricly)
Very interesting...thanks for that info and keep us updated. I need to get that done since my A/F ratio is in the mid-high 13's.
z24 sport once the bugs are worked out , there will be a post for it
mm.. can't wait to pick up a alky kit to go with my 2.7 sitting in fron to me.
Nate
1995 Cavalier W/2k1 Engine
[quote=97cavie24ls(JDM&00s/c sedans™)]john is your crank pulley a different size than the 2.0 eco motor ?? the cobalt guys are talking like 2.8 is the smallest before 16k
My crank pulley is currently the stock eco 2.2, I'm unsure if the size is different. I have the pulley off the redline, I just acquired an A/C pump recently because my engine didn't come with it. So I'll use the redline pulley/AC (alternator is already being used) So I can use the belt without cutting a rib off.
The calculations I did were with the redline pulley size they listed online. If my math was right it would spin the charger at about 15970 rpm or something like that
with the 2.6" pulley. I'll try the 2.8 first and go down from there if I can and measure the sizes of the pulleys to be sure.
yeah on the g/fs cav im going to be using all the 2.0 s/c pullies
maybe they are figuring that the gm stage upgrades are upping the redline to 7000 and saying thats when the s/c maxes
only way to know is do it
ive got the 2.5" pulley, no fule mods at all, still runs a\f in hte high 12's,..... i dont know whats its at when the waters spraying......
however i think its time for a rebuild.... im only seeing 8-9 lbs or so..... but your right. it feels way "torquier"
good luck.
Chris
'02 Z-24 Supercharged
