Well, I know a couple of a sites but I was wondering if anyone knew some secret websites or different places to buy the following for cheap:
- Oil Line Kit (T3)
- Vacuum Line
- T-Bolt Clamps
- Couplers
- Charge Piping (or even a kit that would fit for a J-Body)
Any help would be greatly appreciated, thanks
i would be more than happy to fab up a charge pipe kit for you
the oil lines i sort of pieced together myself. the vacuum lines, t-bolt clamps, and couplers i got from
www.atpturbo.com, and for my charge pipes, i used 4 2.5" mandrel U bends from summit which i measured, cut and welded to fit in the right spots. prices for everything were actually pretty decent.
for fittings, lines and clamps go to advance autoparts. For charge pipes and couplers go on ebay. Make sure you get 4-ply.
Cardomain|
Myspace
Charge pipes: j-bends from summit racing
Couplers and clamps: Verocious Motorsports
Oil lines: Blaastperformance.com
Vacuum line: Advanced Auto
Boosted Eco @7psi for now....GTO come spring.....
Did my entire kit from Home Depot, AutoZone, and the junkyard
fortune cookie say:
Yeah i had to build my intercooler piping too, however i did use some radiator hosing from peterbuilt for couplers, ended up being exactly the same vinyl material, and a lot cheaper, like less then 20 bucks for a foot. Just in case you find yourself in that position like I did when you build your pipes.
