i have a saab t3 turbo, and sti intercooler, the exh. manifold, BOV
i plan i running 5psi on my stock 2200 motor, what else should i get to go w/ this system to support it
i got a sig warning
boosted cavfire
yes i read all that, but im asking what specifically should i get to run a 5psi application...
do i need to run bigger injectors? how many lb's/hr??? fuel pump? msd-dis?
i got a sig warning
boosted cavfire
no fuel pump no msd and yes bigger injectors.... ford red tops will do fine for 5 psi ... I'm runnng 11 on stock internals, stock fuel pump, with ford red tops, an FMU and an AFPR..... you need those things to make the fuel tuning possible......... 5 psi is nothing ..... and it's good your going to intercool it ... with the intercooler don't hesitate to run 8 psi ....... as long as you have the fuel to match the amount of air for 8 psi.....
Lee
JDM Civic Hatch
STi intercooler? As in the top mount subau intercooler? Why?
b/c its a nice efficient i/c...... yes its a top mount on the subaru, but im modifying it so its a front mount
i got a sig warning
boosted cavfire
i dont see anything wrong w/ using it as a front mount, do you?
i got a sig warning
boosted cavfire
i don't know how much power you can get out of it. and i presume you have a local shop that can weld aluminum so you can make brackets for it?
it has mounting tabs already on it, i dont need to moddify it in anyway, i will make tabs that come off the rd support so it will just bolt right up
no aluminum welding required
i got a sig warning
boosted cavfire
inbredzed (mr. steve) wrote:it has mounting tabs already on it, i dont need to moddify it in anyway, i will make tabs that come off the rd support so it will just bolt right up
sweet. well let us know how it works
