i might be able to get one, it'd be fast if i sprayed some nos on it and ported my head with a dremel.
what blow off valve would you recommend? i was thinking about running 6 psi on stock internals
Your car will never make enough power to even spool a t-76
It'd take all your hp to even turn the compressor wheel
not even if i was sprayin like a 50 shot and had a 2.5' exhaust. maybe i'll run a bi-turbo and use a smaller turbo to spool the bigger one
So I ask, why not just get one properly sized turbo?
because i like the way big turbos sound
LMAO!!!!!
Anyone know anything about the variable geometry turbos?
