does anyone have a compressor map for this turbo? I'm having a bit of difficulty finding it... the specs are as follows:
GT28R
Compressor:
Wheel Diameter: 60mm
Trim: 60
A/R: 0.60
Turbine:
Wheel Diameter: 53mm
Trim: 62
A/R: 0.64
also I'm a bit concerned that spool won't be as good with a 0.64 a/r on the exhaust side... any input on this?
I was originally going to go with a t3 super 60, but for another $80 I can get a ball bearing center section then so be it
this would be going on my 2200 OHV btw
ball bearing turbos spool up much faster then regular turbos.. so i would assume the .64 ar wont be as bad on a DBB turbo as a regular
LE61T PTE6262 Powered
that should be fine for your car, im geting a GT-30R for my 2.0 DSM
Chris
'02 Z-24 Supercharged
Don't be fooled by the .64 turbine a/r. The GT28R uses a
T25 turbine which is smaller than a T3 turbine. Since it uses a small turbine and it is a GT ball bearing turbo it should spool very fast. The Down side is that the compressor is also pretty small. The GT28R does use a T3 compressor but it can only flow 31 LB/MIN, the T3 Super60 can flow 35 LB/MIN. If you don't want to make over 250hp the GT28R is a good choice for you.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
skilz what would be the next step up?
I wanna ball bearing turbo but am not sure which to get
check out the GT2860R
QBE (73H 800573D 0N3) wrote:skilz what would be the next step up?
Since i've seen you mention a few times you wanted to make 450whp, check out the Garrett GT30R.
How about the GT2871R... I'm looking at the GT3071R or the GT3076R after I get my Motec hooked up.
i wish u was still in texas cause i would luv to see your turbo setup that weekend u were here i had to go pick mines up in houston
I agree, a beautiful thing.
All the GTxxR's are dual ball bearing, I don't believe that Garrett makes a hybrid bearing - correct me if I'm wrong.
I'm having a heck of a time finding a GT28 in Canada. Does anyone know who carries them?
Roof Rack Racer (autoxxxer) wrote:I agree, a beautiful thing.
go to http://www.turbobygarrett.com and check for authorized distrubiters in canada. I'm sure one of them will either stock a GT28R or be able to get one very quickly
I did that, and unfortunately the only one it shows serving Ontario is DW Diesel, which has no Canadian offices anyway. It's always a pain in the butt (and the wallet) to pay international shiping, then tax, then duty, then brokerage... you get the idea.
I called around to all the local speed shops, and they all say they can't get them
Roof Rack Racer (autoxxxer) wrote:I did that, and unfortunately the only one it shows serving Ontario is DW Diesel, which has no Canadian offices anyway. It's always a pain in the butt (and the wallet) to pay international shiping, then tax, then duty, then brokerage... you get the idea.
Order one from a shop in the US, then go get it yourself... or just stick it out and pay up.
[QUOTE = spotabee]Order one from a shop in the US, then go get it yourself... or just stick it out and pay up.
Excellent advice. Thank you for your wisdom.
I always thought there was supposed to be free trade, but I keep getting boned by both governments.
john317 wrote:How about the GT2871R... I'm looking at the GT3071R or the GT3076R after I get my Motec hooked up.
johns going turbo?
awesome to hear you going with the m4? when you plan on having everything up and running? cause i was going back and forth about the gt3071r and gt30r, the gt3071r supports up to 450 and says it spools 1000rpm faster than the 30r
... M4
I'll get it hooked up with the S/C since I know it runs. Then after I play with that for awhile I'll swap to H.O. cams and prob. Gt3071R maybe Gt3076R.
Roof Rack Racer (autoxxxer) wrote:Spotabee Racing wrote:Order one from a shop in the US, then go get it yourself... or just stick it out and pay up.
if they give you any @!#$, just tell them that the US is not afraid to take over Canada.
