Exterminator wrote:Jay never said that the stock internals were only good to 283 HP... He never gave a hp figure at all. All he said was that a 60 trim t3 (super 60 or not) is good till about the same point that the stock internals are good for. Your 110% right that the eco CAN handle more than 283. According to HAHN's testing a safe max point is about 300... not that you can't go past 300, but that's the point where your on the ragged edge.
Now looking at my recent dyno sheet I'm making 225 WHP which is around the 260 mark for crank HP. This is at 9.28 PSI When you do a compressor map you'll find that the t3 60trim is fine at this level. I have doen the map all the way up to a presure ratio of 2.0 (14.5 psi) and even at this level the turbo still is fine, sure you wouldn't want to go much farther, but it's ok at that point.
Now i don't have exact numbers here, but in general lets say I'm going to get another 10HP per psi 260 at 9psi now 300 at 13-14psi. Again not that 300 is where the eco will break, but it's getting to the point where any errror in tuning will result in bad things.
The point I'm trying to make is that I have seen alot of people on here get "size happy" over turbos. I have been told by several that my t3 is to small for the eco. The fact is that it seems to match my motor pretty nicely as i am noticing from my experiances.
I do agree with you, the eco can DEFINATELY handle more than 283 under boost.. DEFIANTELY, But jay never said it can't![]()
All love man
Exterminator wrote:60 trim is the "size" of the compressor....
When you look at turbos theres ALOT of information you can find. The most common numbets you will see are the a/r ratios of both the compressor and turbine housings. Basicly what someone means when they say "a 60 trim t3 turbo" is a t3 turbo(t3 is simply the style of the turbo), with a 60 trim compressor, as opposed to a t3 with a 42 trim compressor.
Theres alot more to it than the following statment, but in general the larger the number of the compressor (and turbine) the more air it will flow.
Spotabee Racing wrote:Exterminator wrote:60 trim is the "size" of the compressor....
i believe the T3 Super 60 is a 57 trim compressor wheel. It's a .60 compressor a/r and a .48 exhaust. It's a quick spooling turbocharger that will give you some pretty decent top end power. Now, if you start getting into higher boost and if you have head work, you'll have NO PROBLEM spooling a T3/T04 .60 / .63 57 trim
