well, last week i was driving home, ( i now have the 2.5" pulley on) and for one reasion or another it went up to 10lbs @ about 3-4K.... i was like WTF!, it usely only hits 8-9lbs at 6500. then the pulley sheared off the hub and the belt riped its self apart.
i fixed the problem, taped new bolt holes in the hub and grinded more materal off the snout. ( it was rubing.) my queston is, why did it boost what it should be with the pulley. my only guess is that when the pulley was "falling off" it was "twisting" the belt so it wouldent slip.
what belts are people with the 2.5" pulley running.?
Chris
'02 Z-24 Supercharged
boost will spike if the temp drops down enough, i know with my turbo setup ill creep about 2 - 3 pounds on a cold nite over what i see in the daytime.
parting out my built and boosted 97 z24 so4x4.com/cavy.html for pics and a parts list
Taetsch Z24 wrote: then the pulley sheared off the hub and the belt riped its self apart.
Damn, man!!! It sounds to me like the boost spike was the least of your problems!!
Wild Weasel wrote:Taetsch Z24 wrote: then the pulley sheared off the hub and the belt riped its self apart.
yup...... good to hear you retapped that bizznatch...... hope she does't blow up again on ya...
forget boost spikes... just let off the gas.... how hard is that ??
Lee
JDM Civic Hatch
my normal psi range is 5-7 , and on cool night ive seen as high a 9-10 psi right before redline
sounds like fun to me!
ya its back together, runs just like befor.... but i want my 10lbs at 3500 agane!!!!.. and that was with out hte water injection..... lol. im sorta thinking that the bypass valve may be not closing all the way. .... idn
Chris
