ive heard conflicting info on this and have stuck with the stock plugs with various gaps anywhere from .030 all the way to .050 with and without the msd and I still get the 0300 misfire code im specifically interested in the NGK or Denso or the autolite 103s
I am using the stock plugs gaped at .045 no miss fire codes. i have had the plugs out a few times to check them no signs of over heating.
autolite 103's..gapped at what my stocked one's were gapped when i took them out.
gapped @ .060 No missfire code yet. 10k miles @ only 5 PSI non intercooled.
i currently have stock plugs (ac delco) in it which i replaced when i got boost ive tried gaps anywhere between anywhere from .030 all the way to .050 and its always a problem, im thinking maybe i need a different type of plug i dismissed it as a possiblity in the past but im open to any options to solve this code 300 random/multiple misfire
103s gapped at .025. get rich misfire codes 85% of the time when i make a quarter mile pass. the stock ignition is no good above 4200RPM at 10PSI or higher. Just cant keep up. PERIOD.
5K PB: 24:50
10K PB: 54:26
hmm maybe its time for the msd programmable
Stock plugs gapped somewhere around .032. No misfire codes at all.
In my case......NGK TR6's (4177) gapped at .032 = No missfire codes anywhere from 5psi to 12psi. When gapped at .035 I had multiple cylinder misfires. I find it interesting some people have the gap as large as .060 I thought the boost pressure would blow the spark out.
I have an msd on now so i do have a stonger spark, how can one tell if its getting blown out
it probly is not getting blown out if youre running lean...
LE61T PTE6262 Powered
whats the proper ngk irriduim plug part # for the eco
