how would i go about telling which program my car is running with?
2000 Camaro V6.
map sensor would help you tell if it was at least flashed or not.
Save a Tranny, Roll-on
15.3@88m.p.h.(I/E)
15.2@94m.p.h.(S/C'd)
15.5@89m.p.h.(Stock GTP)
Not to go off subject...
How did you gain over a second and lose 3mph while adding a s/c?
You'll have to hook up a Tech2 scanner. You can access the program code through there.
BlackZ2401 wrote:Not to go off subject...
Because it got cold as crap lastnight. By that time his car was cooled way down in between his second and 3rd run.
2012 numbers - 4SPD
AUTOMATIC!!
thanks david........
2000 Camaro V6.
hook up with a scaner, on boost if you have a timing avd of 15 or better, no re-flash.
12degrees, reflashed.
Chris
'02 Z-24 Supercharged
