failed emmissions - Boost Forum
failed emmissions
Tuesday, September 20, 2005 3:16 PM
i have a 2001 with the 2200 and failed emission then on my way home my check engine light came on had it checked it reads slow response what can i do to fix it.just had my turbo done for 2 day.need help
Re: failed emmissions
Wednesday, September 21, 2005 4:56 PM
Q: My car has the code P0133, how can I clear it?
A: Code P0133 reads "Bank 1 Sensor 1 circuit slow response"; meaning the front oxygen sensor (located before catalytic converter) has slow response time to the changes in the air-fuel mixture.
Unless there is a problem in the wiring or an exhaust leak, replacing the oxygen sensor most likely will fix the problem. Visit your local dealer for the proper repair.
BTW thats the O2 sensor in the header.
Thursday, September 22, 2005 2:47 PM
even with the turbo??
Thursday, September 22, 2005 7:14 PM
Let's see the emissions readings.
My Car
Thursday, September 22, 2005 10:47 PM
JUCNBST Online
^ he has an obd 2 car he shouldnt have to go on the rollers. unless his state is diff froommm illinios.
Friday, September 23, 2005 1:06 PM
Wisconsin.
My Car
Friday, September 23, 2005 2:49 PM
illinois
Friday, September 23, 2005 5:54 PM
OBDII has to hit the rollers here in AZ...
<img src=http://hometown.aol.com/yogiandbooboo7/images/french.jpg>
Friday, September 23, 2005 8:07 PM
cavtuner wrote:i have a 2001 with the 2200 and failed emission then on my way home my check engine light came on had it checked it reads slow response what can i do to fix it.just had my turbo done for 2 day.need help
Well, do you expect us to do anything with no information!
What are the emission #'s?
My Car
Monday, September 26, 2005 3:23 PM
cat,evap,o2s,o2sheat thats all i have from the emissions paper
Monday, September 26, 2005 4:11 PM
your tapping for the 02 sensor is too far from the waste gate, its gotta be under a foot away. Thats more than likely your problem
