after about a month of setbacks the motor is finally done and tested. It has eagle rods, wisco 8.9:1 pistons .020 over bore, the block has been bored.020 over, Spec Stage 3 clutch, Spec flywheel, Cometic Headgasket, ARP Headstuds All New bearings/seals/stretch bolts, New Timing assembly kit and a few more goodies I have the hahn manifold on the way and the portfueler setup. i am hoping to put down some good power with this setup i will be sure to post vids at the track and on the dyno as well. I will also be putting on my madrel bent 3 " exhaust when it is all finished we should be done by the end of the day or early tomorrow
---- no engine -----
did you port and polish the head at all ? or put cams in it ??
looks like alot of fun , and pain sitting there
LOL
good luck
wow that is going to absolutely RIP tits. Have fun
z24 aint afraid of no ecotec
WARNING
....... DO NOT RACE A RED ECOTEC CAVALIER IN TAMPA FLORIDA !!!!
THEY WILL F*$KING SMOKE YOU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
JDM Civic Hatch
Sh*t man... were gonna have almost identical parts (other then the fact I have a sc lol)
how many pounds are you gonna run?
i have to break in the new clutch and motor for awhile and await my new fuel setup but after i get that i want to do at least 20-22 on high boost --- besically whatever i can get away with before the cavi's ecu goes crazy --- i do not have anything really to control spark and since i cannot just throw an msd on the b!tch that will probably be my limiting factor
--- for right now the head is stock except it has been polished i have a head i am going to build but right now i need a running car -- larger valves, valve springs, retainers, port and polish, cams and cam gears are all in the future -- we will see what i can do with this setup for now.
looks sweet. how much did everything cost and where did u get it at? did u go with the 440cc or the 550?
Looks very nice man.. Thats gonna be a beast. I have the same project going on right now with my 2.4 spare.. Keep the pics coming
2012 numbers - 4SPD
AUTOMATIC!!
people have been using MSD's with out any problems
just requires a few extra parts for them to work
BlackZ2401 wrote:Sh*t man... were gonna have almost identical parts (other then the fact I have a sc lol)
and a LD-9
Chris
'02 Z-24 Supercharged
Hey my sister is in jacksonville. I was planning on spending about 2 weeks their in feb.
I would like to hang out because by then I should have my engine done.
If you would like send me an e-mail
joshcsepegi@hotmail.com
I do have something for you though the turbo you have has a hole for a internal wastegate. Your running an external wastegate. Just so you know you will have to make sure that hole is covered or your turbo will not spool up to good.
