Using the modified and polished valve cover from JBP, Karo's valves, JBP F/I cam, and Crane 1.6 rockers for a 2200, will clearance be an issue at all?
Thanks Homies
with the modified valve cover u should be fine.
Spotabee Racing wrote:Using the modified and polished valve cover from JBP, Karo's valves, JBP F/I cam, and Crane 1.6 rockers for a 2200, will clearance be an issue at all?
Thanks Homies
I had the JBP f/i cam, and 1.6 rocker rollers from comp cam, karo's larger valves, and didn't have any changes to my valve cover, and it cleared fine. But u have the ones from crane, are those the gold ones, u should be fine with the modified valve cover.
You'll be fine
Both valve cover and piston clearance
................Which car will hit 400 whp first???................
VTLoki wrote:Spotabee Racing wrote:Using the modified and polished valve cover from JBP, Karo's valves, JBP F/I cam, and Crane 1.6 rockers for a 2200, will clearance be an issue at all?
Thanks Homies
yea the 2200 i'm building will have the gold rockers from Crane
hey guys help me out i am lookingb for the part # for the springs for the 1.6 rollers for a 97 2.2 any help appre
