jsut as the title says. everty time i see a s/c Z that goes to the dyno, they are strugglin to hit the 200+ mark for there car. why is that? and i'm mean wiht out N2O too!
" ..TQ is SPEED, HP is BRAGGING RIGHTS.. "
Simple fact, a turbo will always make more power at the same boost level that a supercharger due to the fact that it takes hp from the motor to spin the supercharger.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
And, if the turbo is intercooled (as I'm sure just about all of 'em are), the charge will be more dense than from the s/c, which will make more power.
mainly because only women use super chargers.
but there are advangates. if you have a supercharger at 10lbs and a TC at 10lbs. on a autocross teh SC will spank the TC due to lag.
Kick azz is my boost hero!!!
ok, i see thansk for the help guys!!
Jcavi wrote:mainly because only women use super chargers.
not if you get a properly sized turbo which peaks boost at 4000 rpm, isn't autocross all about high rpms ? then there would be no lag problem.
15.891 @ 88 mph stock, still getting @!#$ty launches...
all about how much air it can push.
PSI vs. CFM.......
..... and heat......
..... and parasitic loss.....
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
yeah I was debating weather or not to put that but really to properly sisze a turbo you need to have your exhasut and compressor housing custom made along with a few other things a custom built turbo is upwards of 1000 which is more money then most boosters on hear are willimn to spend.
Jcavi wrote:yeah I was debating weather or not to put that but really to properly sisze a turbo you need to have your exhasut and compressor housing custom made along with a few other things a custom built turbo is upwards of 1000 which is more money then most boosters on hear are willimn to spend.
or just port the housing...
you dont have to custom do all this. you can just ask people around at what rpm their turbo setup spools, and deduce which size turbo you want.
lag with a turbo? like said above, choose the right one. I see boost at 1500rpm with my 2.3. Size it right and you'll be fine.
Gilles
2.3 Ho
What size is your turbo.
Thanx Charles
s/c porting would be nice. if u look down into the s/c that opening is small. I found a company that will port the s/c but not sure if i am going to go through with it.
Actually my buddy has a 2001 2.4L turbo Grand Am, and i have a 2001 GM supercharged sunfire and we make the same hp at the same psi... or atleast with in 5hp of each other...
The First Twin Charged jbody
Josh F wrote:Actually my buddy has a 2001 2.4L turbo Grand Am, and i have a 2001 GM supercharged sunfire and we make the same hp at the same psi... or atleast with in 5hp of each other...
does he have a different drive train, different wheels,,,,,, things like that could take away hp
Charles - It's a T3/T04E. .48 exhaust and .70 compressor.
Gilles
2.3 Ho
ya im auto and hes standard, and i got 17's, i think he does 2 tho, watevs
i put 175hp and 200tq at 5 psi, untuned proly in 10.9's er so
<a href="www.daptronics.com">www.daptronics.com Huge Discounts on Electronics</a>
DanteMustDie wrote:Jcavi wrote:yeah I was debating weather or not to put that but really to properly sisze a turbo you need to have your exhasut and compressor housing custom made along with a few other things a custom built turbo is upwards of 1000 which is more money then most boosters on hear are willimn to spend.
ahh but yout missing the most important part. Differnt ebinges at different locations with different weather mods etc.... you get the idea will act differently. Because I live in PA means my turbo will spool and act differnetly then other ones. but for the most part your right.
