Hey guys,
well..first off.. which is the open position? Where it sits normally (ie. off car). or when u push the rod all the way out? Need to zip tie it in the open position so it won't build any boost before i get reflash done.
Thanks for the help!!
Nate
1995 Cavalier W/2k1 Engine
with the car off the valve is closed , while your looking at the valve
have a friend start the car and it will open up , that will tell you which way you need to tie it up
