IAT sensor and turbo kit - Boost Forum
Sunday, August 07, 2005 11:59 PM
this sounds like a lame questoin, but where did everyone put their IAT sensor when they put their turbo kit on? when we put my hahn kit on, there was no place in the piping to put it, so its just hanging.
i can tell a huge difference durning the day when its 95 degrees and at night. will the heat in the engine bay make that big of a difference on the IAT sensor?
should i try and move it to a cooler spot or just leave it the way it is?
Re: IAT sensor and turbo kit
Monday, August 08, 2005 6:55 AM
Take off the charge pipe, weld up a bung and install a threaded screw-in IAT sensor just before the Throttlebody, just like stock.... and then plug the harness into the sensor.
Done and done.
-Chris-
-Sweetness-
-Turbocharged-
Monday, August 08, 2005 9:20 AM
yeah you really need to have it hooked up , the IAT provides the pcm with some of the info needed to adjust timing and fuel curves
and it is best in the charge pipe before the tb
Monday, August 08, 2005 11:33 AM
Yeah, a lot of people leave it out, but I'd suggest having it in. The car acts really funny when it's not reading the right temperatures and shifts SUPER hard... with an automatic.
MaximumBoost.net
1-888-TURBO-31
sales@maximumboost.net
TAX ID: 45-8013458577-3
By the way, if you can't do it, any exhaust shop should be able to tackle the job.
Good luck!
MaximumBoost.net
1-888-TURBO-31
Monday, August 08, 2005 12:38 PM
Dave Premium Member Online
SunfighterGT wrote:Take off the charge pipe, weld up a bung and install a threaded screw-in IAT sensor just before the Throttlebody, just like stock.... and then plug the harness into the sensor.
I would not do what he said. A screw in IAT sensor sucks, and the stock sensor will leak boost. Put the sensor in the turbo inlet pipe, right after the filter.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about
the former." - Albert Einstein
Monday, August 08, 2005 1:01 PM
That is wrong, you may as well hang it in the engine bay then...The computer will be getting a false reading of the incoming air going into the intake manifold to make the proper adjustments....
You want to do llike everyone else did and buy the camaro V6 IAT sensor that is metal and allready threaded (not plastic and a rubber grommet like ours) and get the 3/8ths bung for it (cant remeber if its 3/8ths or 5/8ths), drill a hold in your charge pipe right before the TB and weld the bung into it ...screw in the IAT and plug it in, and presto!
the threaded IAT sensor part number is floating around the .org somewhere, just do a search if you wanna find it. It was like $17.00 of something close to that.
Monday, August 08, 2005 1:07 PM
ill still swear by using the IAT in the charge pipe before the tb
if the iat leaks anything , im sure it would measure in very small amounts , or the iat would get blown out of the pipe , or blown to bits from the boost pressure , which would cause a great leak
my cav actually ran better non-intercooled than it did after the intercooler was installed , besides the extra length in pipe , the iat being placed from the charge pipe to the inlet pipe was the only difference
plus the GM s/c has the iat in the charge area , and not the inlet side
people can argue low boost vs high boost all day long , and ill still knowing the temp as the air is going into the motor is better than knowing what is going in just past the air filter
Monday, August 08, 2005 2:15 PM
Pardon me?
Have you RUN the screw-in IAT sensor with boost? I do... and it reads 100% fine on the scanner... it actually reads better than the old stock one since I guess it was dirty or old.
On top of that if the sensor sucks then why is it listed as a coolant temp sensor? yeah we use the exact same sensor for our coolant... so you might as well unplug that too since it sucks.... and on top of that the 2.3 came with that sensor plugged right into the manifold... I guess GM didn't know what they were doing....
What do you propose we do then, Dave? Positive pressure is not a pretty thing, if I can blow a T-bolt clamp at 14 psi I'll certainly blow that piddly stock sensor out of a charge pipe the first time I stomp on the gas.
Run no IAT sensor? As-if... I'd like my computer to read the proper ambient temperature before the throttlebody.
You do me one better... let's put the IAT sensor in BEFORE the turbo. Oh that's a great idea.
Let's get a reading of the intake temperature BEFORE it goes through the compression process, gets heated up, passes through 4-5 feet of piping and across an intercooler core designed to drop the temperature of said air...
By that point the tempertature is so drastically different it's not even funny.
All brilliant ideas, Dave. Bravo.
Do yourself a favour, do NOT do what Dave said. Get a sensor in before the throttlebody where it belongs.
I don't know about you but I'm not into hooking my sensors up in stupid locations on my car. I put things where they were DESIGNED to go.
And Dave if you detected a sarcastic tone, guess what, I meant it. Next time you lay down an opinion like "A screw in IAT sensor sucks" maybe you should explain yourself a little better than nothing at all. I don't care if you run this site, that was probably one of the stupidest things I've ever seen you say on this board, and a complete PILE of misinformation backed up with zero proof, fact or even a shred of personal experience.
-Chris-
-Sweetness-
-Turbocharged-
Monday, August 08, 2005 2:26 PM
dave is going of what the guys over at racers edge told him
they said that a good intercooled system will run the same temp at the inlet and at the tb after its cooled
my problem with that is we do not live in a perfect world , people use intercooler sprayers , which will cool more than the inlet temp
and any pressure drop from any type if iat , is gonna be unmeasureable
Monday, August 08, 2005 2:38 PM
thats where i have my IAT. and dave...its not leaking any or sucking at all. sorry but your wrong man.
5K PB: 24:50
10K PB: 54:26
Monday, August 08, 2005 2:56 PM
The problem with the screw in brass type IAT's as I understand it is that they'll heatsoak. I'm guessing's it's particularily bad when they're screwed into a big chunk of metal such as the HO manifold. They work fine as coolant temp. sensors since in that case they're screwed into a plastic housing which makes them less susceptable to heat soak.
I've also heard that the stock plastic IAT will leak. In hypsy's pic it looks like there is a large brass fitting on the IAT ... it doesn't look like a stock 2.4L IAT to me (maybe it's just the pic though).
mj
Monday, August 08, 2005 3:04 PM
STFU and think about it for a minute. The brass threaded IAT sensor that you so insist on using is prone to HEAT SOAK! The stock plastic sensor will leak boost. You can epoxy it in if you want, but the sensor BODY ITSELF will leak boost. Sure it will be a small amount, but why do you want ANY boost leak at all?
Now, if you place the brass sensor in a better location, maybe you can avoid some of the heat soak, but I believe it will still give false readings when it gets too hot.
If you have an effective intercooler setup, your intake air should be pretty close to ambient air. Therefore, putting it in the intake should be just fine.
Monday, August 08, 2005 3:07 PM
HEAT SOAK!
That means
FALSE READINGS!
And suddenly it becomes just as pointless as you claim it is if not in the charge pipe.
So you tell me, who is right here?
You say my way gives you false readings, I say your way gives you false readings.
Monday, August 08, 2005 4:21 PM
I will give my .02........I rigged up the stock plastic IAT. I work at napa so I have easy access to a ton of jimmy riggin parts...lol. Anyway I used part # 784634 rubber grommet and a 9/16" washer. I welded the washer to my charge pipe just before the t.b. Then I inserted the rubber grommet...very very tight fit btw. Then the iat goes into the rubber grommet extremely tight. I had to use silicone on the grommet to get it in. And I was surprised I got it in without breaking it...lol. But it seals 100% while using the stock sensor. After a couple hundred miles I will turn up the boost to somewhere around 15-17ish and I will know if it leaks or anything. But for now I am only running 8-10 for break in. BTW, it doesn't look half bad either. But I would not leave it hang out in the open!!!
Monday, August 08, 2005 5:07 PM
Heat soak?
WHAT heat soak?
My pipe just before the TB is DEAD cold thanks to my intercooler.
I don't see a problem with heat soak, I'm not running a GM charger here.
...... heat soak. Got any more brilliant ideas as to why it won't work?
-Chris-
-Sweetness-
-Turbocharged-
Monday, August 08, 2005 5:32 PM
SunfighterGT wrote:Heat soak?
-Chris-
The piping before the TB on my 2.2 is usually warm after driving in the summer, and my car is intercooled. So I can see where Dave is coming from about the piping being heatsoaked.
275hp & 306tq - 1999 2.2 ohv
13.2 @ 108 mph
Monday, August 08, 2005 6:07 PM
I had mine screwed into the port on the HO manifold. What's the difference if it is in manifold, or just before the t/b? Honest question. . .
Matt S.
<a href="http://www.cardomain.com/id/kindofcavy"><img src="http://img61.exs.cx/img61/8537/J-Sig8b.jpg" alt="Image Hosted by ImageShack.us" /> </a>
Built not bought, check that!
Monday, August 08, 2005 6:21 PM
my cold pipe gets warm to while driving so I kinda agree with dave on this one, I was going to get it done the way you said chris but a race shop around here said just to tie it in a good open location so it gets air.
LE61T PTE6262 Powered
Monday, August 08, 2005 6:33 PM
heat soak isnt as big of a issue as some of you think , and if you do a search for the post i ahd for the screw in iat , the iat isnt made like the coolant temp sensor
once the air is moving the temp of the pipes is irrealivant , and they do cool down to the touch
Monday, August 08, 2005 7:03 PM
mine is threaded directly into the plenum box from hahn. the sensor and that box thing or normally cool to the touch as is the piping when driving normally.
if i go like 6 or 7 passes in a row the sensor gets a little warm but it has never given a false reading that ive seen on the scanner
5K PB: 24:50
10K PB: 54:26
Monday, August 08, 2005 7:56 PM
So the IAT sensor helps the computer adjust the timing? I dont really care about the fuel changes considering the PCM has no knowledge of my larger injectors and FMU. But the timing could play I role a suppose? Thanks.
Monday, August 08, 2005 9:15 PM
the fuel is important , and plays as big of a roll as the timing
you dont want the computer dumping to much or to little
Monday, August 08, 2005 11:58 PM
97cavie24ls(JDM cav sedan) wrote:once the air is moving the temp of the pipes is irrealivant , and they do cool down to the touch
And therein lies the problem. I couldn't have said it better myself. ONCE THE AIR IS MOVING, heat soak is irrelevant. Well, what about the first few minutes before you get moving? What about sititng in traffic?
If you don't believe that it is a problem, go search for IAT heat soak. I have seen actual tests on other vehicles (the Dodge Dakota comes to mind) where the sensor reading was upwards of 150 degrees because of heat soak. Sure, it is only that way until you get moving - but do you really want your car to not run correctly until you get moving? What's that all about?
With your average every day turbo system, when you just don't have the time to research, buy or fabricate, the IAT in the intake is not going to do you bad, if you have an adequate intercooler.
Anyways, I am not arguing that putting the sensor in the charge pipe (after the intercooler of course, I have actually seen people put it before the IC) isn't the best place for it. It is, in fact the best place, since what you want to know is the temp of the air actually going into the engine. BUT, you have to put a lot of time and thought into it, otherwise you will either have problems with heat soak or pressure loss.
The sensor that was discussed in another thread, I believe its a Camaro sensor, which has a plastic sensor element and metal threads might be a good way to go - BUT you need to make sure you don't get any pressure loss with it. Epoxy is a good thing.
Tuesday, August 09, 2005 12:07 AM
97cavie24ls(JDM cav sedan) wrote: IAT sensor that screws in , great for turbo's
Author: 97cavie24ls(JDM cav sedan)
Date: 07-04-04 01:46 PM
well guys ive been running a screw in IAT sensor in my 97 , its been trouble free no codes
this is a GM IAT sensor , part # 25036751 its from a 3rd gen camaro , its for the air cleaner air temp according to the dealer
gm parts direct info , GM PART # 25036751
CATEGORY: Computer Control Sensors
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $36.46
OUR PRICE: $18.23
DESCRIPTION: INLET AIR TEMP SENSOR
i dont remember what size the thread is , but it will be a good alternative for those on turbo boost , and is will screw into your charge pipe , and not use a rubber groument , that eventually gets damaged and causes pressure drop
its a direct plug in to our stock harness , so no modifing the plug for the 2.3 LO & HO IAT sensor
i figured it was time to share the info for you all out there in BOOST land
enjoy
