i have a 2200 with a cav conn kit no intercooler . its a auto 3spd . the problem is that it feels slugish . im running 6 psi with 250cc inj areomotive afpr at 45lbs its boost dependent so at 6psi its 51lbs . the head is ported and 2 1/2 full exhaust. high rev 255 in tank pump. . by rights the car should be running about 180 hp at the crank . but it feels like my buddys ecotec pulls harder than my car . i have a safc im going to get hooked up and a intercooler put in . funding is problem right now for those .lol. the car is running hotter than normal about 3/4 . HELP PLEASE!
13's or blowning it. one way or the other!
Well you live in FL with no IC and running 6 psi on a auto 3speed. Sounds like yer at right about where you should be all things considered.
Dude You NEED an intercooler. I was running 4 psi on my car non intercooled. Then I got a free DSM side mount so I said what the hell and put it on. I noticed a huge differance, and the car runs so much cooler and smoother. I wasnt knocking either way also . some one is bound to say it
250cc injectors at 51 psi can only support about 140hp. So your probally running dangerously lean.
Invest in a wideband or take it to a dyno to find out for sure.
i dont know the real hp of the car that was just a guess . i was told 250cc -270cc inj would be ok on 6-8 psi ? i have some 310cc inj the shop that sold them to me said on those i should be able to run 10psi intercooled on them and be safe? thanks for the info though
If you want it to run cool put in an aftermarket fan on a toggle switch and take out the thermostat. I know your not supposed to do this but my 2.2 now runs at 150 all day long compared to 220.
do you have a wideband? EGT gauge?
these are pretty important with an n/a car thats been turbo charged.
TheFlyingSquirrel (PJ) wrote:do you have a wideband? EGT gauge?
and proper fuel delivery components.
jamesn29 wrote:13's or blowning it. one way or the other!
All I can say is you better spend alot more money on more than just an intercooler...
P&P Tuning
420.5whp / 359.8wtq
