Could you please post your pics of Auto setups. I am trying to figure out how to run my piping but I'm having a hell of a time. I have the piping from the TB to the IC ran, but don't know where to clock the turbo to, and run the piping. Pics between the firewall and motor would help alot.
Jason
USACi =>146.9db
hey man y do u have coil packs for the quad 4
and where did u get ur pipeing from it looks sweet
and 1 more thing. srry. what map sensor r u useing?
i got rid of the idi cover and coilpacks because the stock ones suck and tend to burn out, and i just wanted to be different. i have never seen a 2.4 done like mine...
all the piping was made from manderel bent exhaust piping that me and a friend cut and welded to fit, everything was built ourselves
and im using a msd 2 bar map sensor, it works fine. i just had to put a different connector on my wiring for it to fit.
so wait the 2bar hooks up directly to your comp. if this is true than Why do people need a flash for there comp.
Kick azz is my boost hero!!!
he has the flash
yes i have the reflash.
this is about the only pic i have of my down pipe, this was taken in the process of building it, it wasn't done only tacked together for test fitting. and i don't realy have any pics of it on the car
this is how i ran my pipes on my auto car
also derek do you have a wire diagram for how you ran your msd, i bought the box, and coils, i just havent gotten around to wiring it all up
damn that is a sweet as$ engine bay/ set up derek. nice work.
Yo brandon, What size pipe can fit between the tranny and the radiator?
i ran all 2.5" pipes
Those are both beautiful engine bays. Thanks for posting the pics guys.
Jason
USACi =>146.9db
^^^ Agreed, this definetly helps with me too when I have to run my IC piping. Thanks guys.
