im having trouble finding my tach sig for my SAFC-2...i dont have a tach sig in my fuse box idn y but there isnt one...where else can i get a good tach sig..right now im hooked into the alarm b/c chevy said thats where you can find one but im 300rpms off. everything is set on the Safc-2 i just cannot find a strong tach sig. like i said everyone said theres a pin in the fuse box but i guess my cavy sux lol its a 99 by the way. so if neone could help me out that would be great...
speed kills, drive slow, drive a honda
You are what you Drive!
Dont know where the hell "everyone" gets their info, but there has never been a "tach" signal in a fusebox of a Jbody....Its at the ignition module....should be a purple wire with a white stripe.....You can also find it at the PCM, but you have to know what connector you are looking for....
P&P Tuning
420.5whp / 359.8wtq
on a 99? neone else wheres urs connected
On my 96 it has a tach signal in fuse box under the hood. Its the #10 pin on the black connector from the ECM.
O noes!
ImPhat0260/Cavattack2000 wrote:Dont know where the hell "everyone" gets their info, but there has never been a "tach" signal in a fusebox of a Jbody....Its at the ignition module....should be a purple wire with a white stripe.....You can also find it at the PCM, but you have to know what connector you are looking for....
Completely wrong on never being one in the fuse box. It was in the fuse box of the 95-98's and some 99's. The fuse is in the fuse box under the hood and I guarentee you its there, since I had a 98 myself.
The tach signal, as I know I've stated in MULTIPLE posts where you've asked this question, can be had on Connector 2, Pin 10. Even if there isn't a wire there, you can get the tach signal there, and its a full signal.
im also wiring up my safc2 and also have a 99 cavalier, where exactly is connector 2 pin 10? im sorry im terrible with wiring, are u talking about in the fuse box? or the diagnostic port? or elsewhere? please school me on wiring shifted
thanks
Holy crap, I just said where to find it. And I'm the guy who actually has boosted a couple of J's in his day
When you're talking the plugs off the ECM, the first one will be blue colored, the one behind it is the black connector. Pull off the plastic cap on the connector. You will see they're all numbered. Poke a hole in the rubber on the #10 hole (I used a 12 gauge wire, worked perfect) and slide it until its almost flush at the bottom of the connector.
O noes!
You can lead a horse to water, but you can't make it drink.
You've got to be kidding me.
Click ME!
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
