Hey guys, just have a question for the guys that are running the GM blower, 2000-2002 and water injection, what is the preferred liquid, washer fluid, other? What do you gain the most from? Thanks
not to post jack, but if anybody can give me links to some water/alcohol injection sites then i would appreciate it much
2000 Camaro V6.
www.coolingmist.com
Guys,
I hate to be obnoxious about it but you definitely need to use the Search button.
Type in alcohol and you should come up with tons of stuff that myself and a couple others have already posted on.
i was just looking for links to diff companies, i know of smc, alkycontrol and one other that i cant think of, but the coolingmist helped me out.
2000 Camaro V6.
I have the coolingmist.com stuff. i got it off e bay(he sells on e bay). I payed 200$ about for a single stage kit with a tank.
i have the 1-4psi boost switch. I mounted my tank and pump in the trunk. It is a pretty easy install.
Need any help just let me know.
I run -20 windsheild washer fluid.
Mr. PUTE- does this s/c have teflon on it's blades?
Yes Mr. JAKE. I'm assuming we already talked on AIM about this a couple minutes ago.
Again, alcohol/methanol does NOT cause chemical corrosion to teflon.
The reaction is impossible.
Here's some info again:
http://www.j-body.org/forums/read.php?f=40&i=75605&t=75474
yep, read that when it was first posted, and read it again. in not only looking for alky, but water injection also, or maybe even dry nitrous if that would work. ill make another post about it since this isnt my topic lol.......
2000 Camaro V6.
im running washer fluid which contains 10 percent methanol
wouldnt washer fluid hurt an engine. im new to this so bear with me
CAVI.DEMON wrote:wouldnt washer fluid hurt an engine. im new to this so bear with me
This is what I was thinking. Sure, it's got water and alcohol... but it's also got some other crap in it to make it clean glass nicely... and that stuff's not meant to be exploded in an engine, right?
Why not try ethanol....it wouldn't have to be absolute, just reasonably concentrated. Regular gasoline already contains ethanol, so it's obviously safe to run in our cars.
well my coolingmist kit isnt working now for some reason, the pump works, the relay works, even bypassing the boost sensor and manually grounding it still wont kick on anymore, stupid msd has a problem too on that same power wire
^ that sucks.
i think i am going to switch over to some yellow bottle HEET, and some distilled water.
see how that works out.
