Hey,
Has anybody had a gm s/c go bad? As in faulty parts. How many km/miles was put on it before it went ka-put.
Nate
1995 Cavalier W/2k1 Engine
ive got about 10k on mine no problems... stock pulley
Ive got about 6k on mine and no problems whatsoever.
At 35K on the unit I had the idler bearing go out, the snap ring inside the hub broke and the bearing turned inside the hub itself, it made a clicking/ rattling noise that resonated inside the blower, made it sound as if the rotors were hitting each other. GM wants 200$ for the whole unit.
I ended up replacing the hub and bearing assembly with just a bearing, it has the same ID as the stock bearing, and 2\10 of a inch larger OD, however it is 1\10 of a inch narrower than the belt.
This has been on for 4-6K miles and it works fine, also with a 2.7inch pulley and a stock belt, I have no slip.
Also I changed the oil in it every 10-15K
I’m happy with it.
Chris
'02 Z-24 Supercharged
10k miles ish no problems
(plus water injection i have used so far 5 times)
