I am seriously tossing around the idea of a low boost non intercooled turbo kit for my 03 base coupe.
I figure 4 psi or so.
Things I woud need:
turbo
turbo manifold
oil lines
charge pipe
assorted fittings and hoses
What for fuel? If I am running low boost like that. Would I be ok with a simple FMU?
Help me out org!
2006 Cobalt SS I/H/E ZZP S2 HPT 2.8/60's Etc...13.8@105(I need to learn how to launch)
Don't forget gaskets, and if the turbo is water-cooled, you'll need some water lines.
You'll be okay with an FMU at 4psi. Just remeber, you're going to want to TURN UP THE BOOST!!!
<img src=http://hometown.aol.com/yogiandbooboo7/images/french.jpg>
can I ask why not just go intercoolered? its like 300 or less for a decent on and its better for the engine. also you forgot wasategate and blowoff vavle.
Kick azz is my boost hero!!!
Internal WG. And yeah some BOV, thanks!
I would sugest to get a intercooler even if it is a small one. even at 4 psi you will be giving your car way more heat than it needs
go to johnyracecar.com or speedpartsrus.com
they have cheap intercoolers
