Can you guys tell which gasket was on my turbo to downpipe? lmao. i got these and they package said these are the last gaskets you'll ever have to buy. "high temp aluminum gakets". im goin back to copper.
[IMG]
[/IMG]
TURBO KIT...$4,000
RUNNING 20 PSI...ANOTHER $2,000
SMOKING THE TIRES ON A 3RD GEAR ROLL...PRICELESS
dang!!! i would go back to copper too
get your money back too if you can
"Official Jewish J-Body"
where are you guys purchasing good turbo, and wastegate gaskets at?
________________________________________________
...bone stock
aluminum is not a good metrial for a turbo any ways , its got a lower melting point than the egt's will be on a turbo
gasket looks like a wall hanger now though
lol
You have a gasket for your downpipe to turbo??
so you guys dont run a gasket from your turbo exhaust outlet to your downpipe elbow with o2 sensor???????
TURBO KIT...$4,000
I know with my internal wastegate, its like a rotating cuff that seals against a flared/angled edge of the downpipe.
<a href="http://www.cardomain.com/id/fireside"><img src="http://www.influx.ca/avatars/stevefiresig.jpg"></a>
JustinsEcotec wrote:so you guys dont run a gasket from your turbo exhaust outlet to your downpipe elbow with o2 sensor???????
No. I have a 5 bolt flange that bolts directly to the turbo (flat surface), no gasket.
I need a gasket like that for my turbo... I have an internal wastegate also so its just a three bolt... there was no gasket on it and it was leaking there so I'd assume a gasket should be there.... where can you order copper ones?
what kit was that roasted gasket from?
