i have a 99 Z thats boosted...finally and i think i wanna run a MSD set up. now i see a few people running MSD set ups and lists consist of
MSD Dis-2
MSD Blaster Coils
MSD GM interface modules
MSD Heli core 8-mm cables
now my question is how many blaster coils? since its plural or is it coils as in 1 unit that just contains many. i dont wanna over buy or under buy. also i dont wanna buy the wrong stuff im on MSD ignitions just looking for names of waht i need. its confusing..another thing to tell you the truth i dont even know what to exactly to buy so if anyone can direct me on what i need that would be great...thanx
speed kills, drive slow, drive a honda
You are what you Drive!
you need 2 of the msd coil packs
believe they are P# MSD-8224
yea thats what i htought just wasnt sure how many..thanx a lot anyone else on any of the other things..
thats exactly what im running
Dis-2
Interface modules (2)
8224 Coil Packs (2)
MSD 8.5mm plug wires
if u dont mind me asking where u get it and how much did all that run?
thanx
about 450
what did you have to do to convert from the IDI to the 2 coil pack ignition? I have the write up saved that Misnblu did....just wondering if you used that or something else.
basically stock it goes from the ICM to the coil packs to the plug boots, when you go to msd from the icm it goes to msd out to adapter blocks, to coils , to plug wires
right...i get that but i'm just wondering what he used to convert to the coil packs from the IDI, a custom wiring job maybe? or something else. i know its not just throw in the coils, plug em in and go.
the wires from the ignition module go to the msd and the msd hooks up to the interface modules, and the coils are bolted to the,... its not much different than hooking a msd to the idi cover it just goes to the coils instead
