Living in California..smog sux azz...I realllllly want to boost my car..but dont think if it will ever pass smog..or if they will just laugh at me and send me home..anyone know?
Elmer the wricer hunter..."Shhh be vewy vewy quiet...I'm huntin wrice"
Kill da wriiiicer...Kill da Wricerrrrr..kill daaa wriccceeerr!!!
Boost does not increase smog in most cases, usually the only time your car is on boost is when you are driving, at a smog station, it would be idling I think. So at the worst, you could get your car certified before you install the kit (good for 2 years I think), then remove it if you need to get certified again.
but wont the boost throw off the computer? maybe throw codes at the smog monster?
kewl sounds good..if i do boost it..will i need to get a diffrent computer for it? or will the stock 03 one work with it?
im pretty sure there is a idle and a highway test
-Borsty
the highway test i would be scared of
Its cost wayyyy to much to get smoged anyways
Move. come here to TN. 0 tests, ever. I could run full open headers and not get pulled over, simply cause i'm still not as loud as the big-ass redneck trucks around here.
~ROTFLMAO~ yeah i miss texas cause of that too..used to piss off the idiots with the fake bull balls hanging off there truck~LMAO~
move lol
From what I understand, you just can't make any adjustments to your exhaust system until after the catalytic in California (any changes must be certified by the CARB). Also, if you take the test, and then put the stuff on, you better pray you don't get pulled over and checked out.
If you really want boost...remote mount turbo...It's not the most efficient system, but it will be legal. Basically, you put the turbo in place of your muffler, then you have to run charge pipes and oil lines all the way down the car.
Everyone laughs at the thought, but I've seen some pretty successful setups. Anyone seen the write-up on the 3.1 cav? I think it was on a f-body forum...
________________________________________________________
-Josh
<img src=>
OHV notec wrote:From what I understand, you just can't make any adjustments to your exhaust system until after the catalytic in California (any changes must be certified by the CARB). Also, if you take the test, and then put the stuff on, you better pray you don't get pulled over and checked out.
Pacesetter is C.A.R.B. legal..and I think magnaflow makes a legal one
Shouldn't the car run cleaner with upgrades with air? I always thought with more upgrades your car runs more efficiently. Well on upgrade I know that would definitely help would be an MSD-DIS2 because it helps to burn up more of your fuel.
