GM S/C 2.5" Pulley Experiences - Boost Forum
Since my qwikchange incident (look down a page or so for that), I've put on a new hub with the 2.5" pulley. When I first threw it on, I was only hitting 8psi because the old serp. belt I had was slipping. A new Gatorback #4050722 belt later, and now I'm back up to 10psi.......exactly what I was at with the 2.6" pulley!!!
This leads me to the question, who else has the 2.5" pulley? I know scooby has/had it. Haven't seen from him in a while on here. Anybody else have any experiences with it since the last time this issue was brought up? I'm mainly looking for what kind of boost pressure you are experiencing.
Since my 2.5" pulley is pushing the same exact amount of boost my 2.6" pulley was, this makes me wonder if the bypass valve is not holding all of the pressure. I know there's an adjuster screw on it that GM specifically says not to touch but I'm curious if that will yield any results.
Any thoughts?
i thought i read somewhere that with roots type blowers they have a draw back when it comes to smaller pullies. And that is, when they get spinning to fast, instead of all the air being forced into the engine, instead it is kept in the blower and follows the blades around and around. Im not 100% sure on this, but it might be that the charger has a mechanical limitation to it. Come to think of it, i dont think ive ever seen anyone run more than 10 PSI on the GM charger. BUt it might also have some kind of bypass limitor too that wont let it get past 10 PSI for safety of the charger. Maybe taking the blower to a shop and having them rebuild it would get more PSI. Other than that, i dont know.
13.91@102.77
I know you can get the S/C ported or something (some guy here was telling me he got his M90 done and so he figured i could get my M45 s/c done too) so that might do something... also i don't know how much you want to play with the s/c but that by pass valve might be holding you back like you said....
I have to ask though... how hard does it pull now with 10psi???
wait doesnt your sc lose efficiency after 8 psi? because of the heat?
LE61T PTE6262 Powered
Freebs wrote:how hard does it pull now with 10psi???
Like I said, I was pulling 10psi with the 2.6" pulley so the car feels the same to me now as it did then.
QBE (73H 800573D 0N3) wrote:wait doesnt your sc lose efficiency after 8 psi? because of the heat?
Nope! Why? Because I'm injecting 1000cc of alcohol/water into my supercharger constantly when I'm on the throttle. After doing a full 1/4 mile run with the alcohol active, I've jumped out of the car and felt the s/c. Ice cold
Mr. Pute wrote:Freebs wrote:how hard does it pull now with 10psi???
yea i know... but how does it pull with 10psi in general...
Mr. Pute I remember that
Mike Jazz was running custom pullies getting 12psi. Why not ask him.
Another thing, Mr. Pute, can you post a pic of the location of your water/alcohol injection nozzle? where do you put it?
___________________________
MAKING MY DREAMS A REALITY
Visit my cardomain site !!!
ELIOT. Now.....boosted.
insane
Freebs wrote:yea i know... but how does it pull with 10psi in general...
It pulls like a freight train......but I want it to pull like a jet
Eliot wrote:Mr. Pute I remember that Mike Jazz was running custom pullies getting 12psi. Why not ask him.
Thanks Eliot, I will definitely check him out. My alcohol nozzle isn't actually a nozzle. It's a fuel injector. I have the injector boss mounted on the underside of the PCV oil vent spacer that comes before the throttle body. I'll see if I can get a picture of it later today.
Jake wrote:insane
Damn straight Jake!
sweet, I wasn't aware ppl were getting 10 psi on those.
Most people haven't tried because of the heat soak. Alcohol allows me to get past that problem.
Alcohol gets me past my problems too!
Stop jacking my thread beotch!
From what I'm hearing, I might be at the point where the supercharger housing is actually starving itself. Porting (a lot) and polishing the housing should up the boost a little.
Has anybody seen over 10psi with their gm s/c? If so, how?
so mr pute your spraying the alcohol thru the throttle body not after??
whats up mr pute, i had the 2.5" i didnt notice much difference at all from the 2.5 to 2.6 boost wise, i rant a 35 shot on it once, man that thinkg pulled hard, but a few monts later when it got hot out i forgot to swap pullies and i popped my motor. I will porally be on here a lot less now, i just traded in my z24 for an 05 SRT-4, picked it up on tuesday. But feel free to E-mail me if ya have any questions.
<img src="http://www.j-body.org/registry/scoobyz24/personal_pic.jpg">
-Bryan Dube
Team Drop Zone
Vice President
^ make sure u get the recalls done asap
and some have recalls on the engines.
i heard thee is no way to intercool the roots type blowers that sucks
i have the rsm kit for the 2.2 ohv and after a run or two i lose all of my power. so i am gonna build an intercooler kit from another carsee if that solves the problem i am also going to put an oil cooler in and wrap my headers temporaliy until i buy coated ones
hopefully the cool hood temps wwill help until the intercooler is built
oh and even tho the rsm kit is rated for 8 psi it regularly hits 10
2000 Dark metallica green cavalier. (2.2 2200) pace setter 4-1 header, magna flow high flow cat, dual quad tip dtm muffler, momo 16in rims, rk sport strut bar, rear vibrant strut bar, JDM Floor bar stablizer, Crossdilled slotted roters with ceramic brake pads, 14lb.carbon fiber oem style hood, rsm lightened crank pulley, MSD Blaster2 Ignition coil packs, RSM Vortech V-9 Supercharger 8psi, 270cc venom injectors, cooltek oil cooler, b&m shift improver.
in another few months i will get the built short black from jbodyperformance.com
"Disarters are just another star falling in my yard."
scoobyz24-- do u still have any parts left from your cavalier boost wise, like pulley's an etc... im in RI an just got the s/c kit, looking for upgrades..
mr pute- is there any way i can contact you outside of JBO, i have sum questions about alcohol injection. im really new to it an i wanna learn about costs an wat parts are involved before i go about getting myself into it. thanks
Proudly Sponsored by: Overloadcars.net
Guys, please stop jacking my thread.
Is there anyone out there using the GM supercharger that has been able to achieve over 10psi??
ScoobyZ24, what kind of boost pressure were you seeing with the 2.6" and 2.5" pulleys?
Bluzr2, you've already contacted me outside of the thread. I'll email you back soon.
sinrocker, alcohol does just as good as an intercooler. No problems here.
illd9, check my registry for my AIM address and email.
I'll be posting an alcohol injection FAQ within the next couple of weeks. Please, let's stick to the topic at hand. Thank you.
pute i honestly dont remember what i was getting for boost on a regular basis w/the pulley, do u already have the 2.5" pulley if not i still have just the pulley ill sell ya for 30 bux, i do know that on a real cold day in january i hit over 10
illd9 all i have left over is a brand new black injen intake cut to fit the s/c
-Bryan Dube
Team Drop Zone
Vice President
got any pics.. sure id take it if the price was right.. email me xcavix@hotmail.com
thanks mr pute, ill be talkin to ya
www.OverloadCars.net
listening.
Mr. Pute wrote:Eliot wrote:Mr. Pute I remember that Mike Jazz was running custom pullies getting 12psi. Why not ask him.
Thanks Eliot, I will definitely check him out. My alcohol nozzle isn't actually a nozzle. It's a fuel injector. I have the injector boss mounted on the underside of the PCV oil vent spacer that comes before the throttle body. I'll see if I can get a picture of it later today./quote]
Hi Mr. Pute, do you have the chance to take that pic?
Sorry...... Wrong quote......
Hi Mr. Pute, do you have the chance to take that pic? about the water/alcohol injector location? and controller?
Regards,
