Where can I find the bolts for my turbo, can I just use bolts from a hardware store, or what? Also, Where have you guys been getting your oil lines?
One more question, I have 2 more ports by my oil lines, what are these for, someone tell me that I don't have to run coolant to these.
Jason
USACi =>146.9db
you can get bolts at the hardware store. get the grade 8 bolts. they're not absolutley necessary but they'll be the last bolts you'll ever buy.
there are some kits on ebay for oil lines for i think $60 or $70 but that seems a little expensive to me. check some local auto part stores for fittings and braided line. i'm sure you could do much cheaper than 70 bucks.
those extra ports are for.....you guessed it...coolant lines. you dont
need to run coolant through there, you could just leave it open or plug the holes, but it would definately help cool the turbo. just run t-fittings off the heater core lines.
you can get the AN fittings for practically nothing and make your own oil lines.
Yeah, don't bother with the eBay oil line kits. I ended up only using the return line out of the entire kit. I saw the exact same steel braided line at Home Depot... I'm sure it wasn't more than like, $7.
~Wayrin
<a href="http://www.cardomain.com/id/wayrin">My Cardomain Page</a>
<IMG SRC="http://www.geocities.com/wayrin/Wayside.jpg">
Yeah, most of the fittings in those kits don't even work for the J-Bodies. Let me know if you need a specific fitting and I'll try to help you out!
MaximumBoost.net
1-888-TURBO-31
sales@maximumboost.net
TAX ID: 45-8013458577-3
