does anyone have pictures of the charge pipes running under their car on a 2.4? ive got a 97 5 spd z24 and in a couple weeks getting my charge pipes done, waiting for my intercooler to arrive now and i was planning on going under the car but it looks kinda tight, so if someone has some pics it would make things a whole lot easier, thanks
parting out my built and boosted 97 z24 so4x4.com/cavy.html for pics and a parts list
sounds good bud, i wont have my ic for another week or two so if you want post them up here or leave me your email addy and ill shoot you a message and you can just pass me the link when you get it all done
ok cool man, sounds good. your going under the drivers side im guessing? i was under the car today and i found a way i want to run it under the car, but dmanit its gonna be close and i dont need to snag a rock or some road debris and take a chunk out you know.
Passenger side, between the engine and the motor mount, coming through under the ECU, curving around into the intercooler, out the intercooler on the other side, up through the bong hole, and over to the throttle body.
Mine is a little more difficult because I have the freaking huge auto tranny.
hmm, you have ac in your car? i was thinking pass side but didnt want it snagging on the pulley, although ill have to take a closer look on the pass side and see if i can route it in there any better.
you have msn bud? leave me your info and ill add you
Yeah I do, it goes under the pulley, really doesn't even come close to it. It goes down by the A/C cannister, takes a 90 towards the motor mount, continues up under the A/C compressor, takes a 90 and turns towards the fender and goes under the ECU, takes a 90 towards the front of the car for about 4 inches, and then a 90 into the intercooler.
You have to trim down the motor mount bolt so its even with the nut, then it will fit between the motor and the mount.
ok cool thanks for the tip, ill cut that down this week and egt it all ready to go in.
i took some quick measurements, i think i can ift the intercooler behind the bumper support if i can find a way to mount it, jt need to see if i can remove those 2 bars that come down on a 45 degree angle. but it should fit, 30x8x2.5
if not ill cut, i dont care, lol
must have a ford parked there, lol.
nice, looks like its meant to fit there huh, lol. thanks for the pic man, ill get the bolt trimmed down tomorrow and once my ic comes in ill yank the bumper and cut what needs to be cut and get it ready to go in
Check out Brandon Fetter........ his cardomain site has some great pics on it.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
sweet thanks speedracer
I looked at brandons pics .... his charge pipe off the turbo sure comes close to the axle ..... clearance issues ? And also it sure is close to the downpipe as well ... possible heat soak ... or did I see some wrapping/shielding on there ..... it sure does fit well beside that coolant pipe ..... great set up
Jay
Jay
with some header wrap or somethign similar you hsould be fine to keep excess heat away form the pipes. id imagne the pipes being under the car would stay cooler because of a constant air flow while moving over being jammed in the engine compartment
no clearance issues at all with mine heres a link to my
cardomain site, go to page 3 that should have all the pic you could need to figure it out
<img src=http://registry.gmenthusiast.com/images/brandonfetter/fettersig.jpg>
thanks brandon, setup looks great
